New here, timing chain question - 460 Ford Forum
post #1 of 6 (permalink) Unread 06-17-2019, 01:54 PM Thread Starter
I have a 75 F250 supercab with the 460. I want to replace the timing gear set with a double roller. Would this beneficial to run this at 0? To gain more power
File Type: jpg Screenshot_20190617-124902_Chrome_1560797660137.jpg (92.7 KB, 21 views)
Supercab is offline
post #2 of 6 (permalink) Unread 06-17-2019, 03:02 PM
Quoted: 510 Post(s)
Do NOT run a billet upper gear on an oem iron thrust retainer. Iron top gear.
That being said a 93 and up EFI replacement double roller timing set is a great upgrade that is cost effective.
All EFI 460 engines had straight up cam timing.
SJ
used 2b RHP
The Mad Porter is online now
post #3 of 6 (permalink) Unread 06-17-2019, 09:59 PM Thread Starter
Thank you for the info
Supercab is offline
post #4 of 6 (permalink) Unread 06-21-2019, 10:12 AM Thread Starter
Is there a different Thrust retainer plate I can order? To replace the factory iron unit?
Supercab is offline
post #5 of 6 (permalink) Unread 07-16-2019, 09:36 AM Thread Starter
I have it figured out and installed, it worked out great. The timing gear came with a spacer that went behind the gear. I took off the factory thrust cam plate and countersink the hole for flush mounting hardware. I have no rubbing or interference from the cam gear. This Billet timing gear set works just fine.
Supercab is offline
post #6 of 6 (permalink) Unread 07-16-2019, 04:23 PM
Quoted: 510 Post(s)
So long as the timing set has a thurst washer or bearing it will be fine.
I did not note the washer from the pic when making my original post. When running billet steel against the soft oem iron retainer severe damage will occur.
