1973 Lincoln 460 - 460 Ford Forum
post #1 of 8 (permalink) Old 06-17-2019, 02:13 PM Thread Starter
1973 Lincoln 460
Right front cooling Passage seems to be plugged. Is this normal.
File Type: jpg A44F71C8-FC43-4461-B822-EE630C4FA659_1560798722256.jpg (6.4 KB, 29 views)
Jim Hopkins is offline
post #2 of 8 (permalink) Old 06-17-2019, 03:05 PM
Quoted: 510 Post(s)
No it is not.
SJ
used 2b RHP
post #3 of 8 (permalink) Old 06-17-2019, 06:14 PM Thread Starter
I just took a photo of the head gasket I removed and the front cooling passage is blocked off. Is this correct?
File Type: jpg DF842264-E124-4F0A-A0F7-10495339ADBA_1560811446901.jpg (12.8 KB, 14 views)
post #4 of 8 (permalink) Old 06-17-2019, 06:21 PM Thread Starter
The first photo is a closer look at rear cooling passage and the second is the front cooling passage of the head gasket I removed.
File Type: jpg E6E4FC73-4902-4C84-B373-20C01F9CF3D7_1560813555341.jpg (12.6 KB, 11 views)
File Type: jpg D85C8DBF-F7F9-4BF6-9354-F82ABF72368D_1560813603412.jpg (11.4 KB, 10 views)
post #5 of 8 (permalink) Old 06-17-2019, 07:05 PM
Quoted: 510 Post(s)
The head gasket is supposed to block that passage to force water to the rear first. If the garbage shown blocks coolant flow around the cylinder then you need to address this.
It appears that some cooling system maintenance was overlooked.
SJ
used 2b RHP
post #6 of 8 (permalink) Old 06-17-2019, 07:19 PM Thread Starter
ok so now would be a good time to clean out that blockage of crud. I also noticed that the crankshaft doesn't have the external counterweight on it. Will this be a problem?
post #7 of 8 (permalink) Old 06-17-2019, 09:12 PM
Quoted: 510 Post(s)
1973 460's are internally balanced. Spacer is not weighted.
SJ
post #8 of 8 (permalink) Old 06-18-2019, 10:40 PM Thread Starter
Thanks for the information.
