Compression ratio with mix match parts - 460 Ford Forum
post #1 of 3 (permalink) Old 06-19-2019, 09:05 PM Thread Starter
Hi, had to change the timing set on my engine so took a look inside while I dropped the pan to fix a tiny leak and flatten the oil pan rail.
Trying to find info on compression ratio (IF) the block is stock. Since idk what (if any) machining its had in its life. Thank you for any help
Block D9TE -AB
Head casting D0VE -C
Con Rods Caps C9AE-B
Rods D6VE-AA
Piston D3VE 6110 A
SkySoldier173 is offline
post #2 of 3 (permalink) Old 06-19-2019, 09:30 PM
Quoted: 511 Post(s)
Block D9TE -AB
Rods D6VE-AA
Piston D3VE 6110 A
Typically 8.9 to 9.1 to 1
SJ
used 2b RHP
post #3 of 3 (permalink) Old 06-19-2019, 11:17 PM Thread Starter
Awesome, thank you!
