No temperature reading on dashboard - 460 Ford Forum
post #1 of 8 (permalink) Old 07-07-2019, 09:45 PM Thread Starter
Quoted: 6 Post(s)
Hi there. I have got 1973 Continental. I just finished little rebuild project. I have installed new carb, edelbrock intake, new radiator, hoses, thermostat, etc. I also got rid of all the emission system including egr thermo switches. Engine runs good but I don't have temperature reading on my dashboard. I'm using old temperature sensor. So I am not sure if this might be related to the fact I got deleted all the thermo switches? Or is it bad temperature sensor? How can I check my temperature sensor without taking it out of my engine? Can I check it with voltmeter? Should I look for resistance? Thanks for any help
File Type: jpg tmp-cam-5303794232410087229_1562553937508.jpg (18.5 KB, 17 views)
Miner is offline
post #2 of 8 (permalink) Old 07-08-2019, 01:27 PM
Quoted: 511 Post(s)
Ground the temp sensor wire and see if it pegs the gauge.
SJ
used 2b RHP
The Mad Porter is online now
post #3 of 8 (permalink) Old 07-09-2019, 08:18 PM Thread Starter
Quoted: 6 Post(s)
SJ
used 2b RHP
<img src="https://460ford.com/forum/images/smilies/biggrin.gif" border="0" alt="" title="Very Happy" class="inlineimg" />
I did what you said. There is two wires; red and yellow. With ground hooked up to the red one I got the reading, but gauge shows max temperature. I don't think that's right &#x1f914;
Miner is offline
post #4 of 8 (permalink) Old 07-09-2019, 08:47 PM
Quoted: 511 Post(s)
Pegging the gauge is what is supposed to happen. Do you have a temp light as well?
SJ
used 2b RHP
post #5 of 8 (permalink) Old 07-09-2019, 09:59 PM Thread Starter
Quoted: 6 Post(s)
SJ
used 2b RHP
Not that I know of, no.
Miner is offline
post #6 of 8 (permalink) Old 07-10-2019, 09:50 PM Thread Starter
Quoted: 6 Post(s)
SJ
used 2b RHP
I tried to hook up my old thermo switches into the harnes to see if this will change anything but no success.
I found something like this online:
"While the engine is running you need to be continually checking the digital ohm meter. You are looking for readings that are more than 200 ohms in variance between a cold and warm engine. If you do not see anything that is more than 200 ohms in difference, the coolant temperature sensor is defective and will need to be replaced."
Is that true? In my case at some point when engine gets warm I stop getting any readings.
Miner is offline
post #7 of 8 (permalink) Old 07-17-2019, 11:43 AM Thread Starter
Quoted: 6 Post(s)
SJ
used 2b RHP
So I guess I do have temp light, because my temperature sensor have to prongs, that's my assumption. I don't know where it would be located on the dash though.
Miner is offline
post #8 of 8 (permalink) Old 07-17-2019, 02:35 PM
Quoted: 32 Post(s)
hi a temperature light well be one of the red idiot light that comes on when you turn the key on before you start the motor. might have a picture of an oil can or the motor. if you have one.
good luck
tim
61 Comet W/200
pedal2themetal45 is online now
