71 460 - 460 Ford Forum
 2Likes
  • 1 Post By pedal2themetal45
  • 1 Post By The Mad Porter
post #1 of 5 (permalink) Old 07-21-2019, 05:13 PM Thread Starter
So she was running fantastic and I thought I heard too much chatter in the valves and tried to readjust valves and I’m having the worst trying to get her running right again, as of now she cranks right up and sounds good, but white smokes out of passenger side bank, does good on initial acceleration and then with more gas given she shudders hard and more white smoke
dads65 is offline
post #2 of 5 (permalink) Old 07-21-2019, 08:44 PM
Quoted: 184 Post(s)
pic of valve train
what heads? rockers? etc
BUY,SELL, or TRADE BBF parts
Dynoed or Test STAND RAN
CYLINDER HEAD PORTING
HEAD FLOWING
PRO SYSTEMS CARBS
BOSS 302 351 429 800CI+
BOSS 429 is offline
post #3 of 5 (permalink) Old 07-22-2019, 08:21 AM
Quoted: 36 Post(s)
HI, Heavy White smoke out a tail pipe is a strong indication of a blown head gasket..
good luck
tim
The Mad Porter likes this.
61 Comet W/200
pedal2themetal45 is offline
post #4 of 5 (permalink) Old 07-22-2019, 12:46 PM
Quoted: 521 Post(s)
good luck
tim
Agreed.
I've also seen a few times where a bad modulator valve can cause a white leaning to light blue smoke show.
SJ
used 2b RHP
pedal2themetal45 likes this.
post #5 of 5 (permalink) Old 07-24-2019, 06:48 PM
just a thought
Just curious if you may have been playing with distributor at same time you heard what you thought was a valve train noise.
If timing was way out the rattle could have been detonation.
It does sound like a head gasket is one of the most common issues for white smoke and I have had a bunch of modulator smoke shows as well .
I did have a friend of mine attempt to set his own timing when we were kids and hurt his motor after hearing multiple death rattles (Detonation) out of his top end before he called me for help.
He ended up hurting a piston by continually running it way out of time trying to figure it out. He was too embarrassed to call in the beginning and didn't realize what the noise was. Detonation can be very destructive.
Any other specifics on what you might have been working on before this occurred or how you may have been driving would give us a little more to work with.
Jon D is offline
