460 Fox Body swap Waterpump - 460 Ford Forum
post #1 of 6 (permalink) Old 07-25-2019, 12:27 AM Thread Starter
I have been told that there is a mechanical water pump that allow for a fan on the engine side of the radiator. Does anyone know the part number of this water pump and what applications it was used on? Thanks
Jim Hopkins is offline
post #2 of 6 (permalink) Old 07-25-2019, 09:01 AM
Quoted: 100 Post(s)
https://www.460ford.com/forum/42-gen...nical-fan.html
The alt bracket is my own doing as I wanted the AC compressor on the rh side
thermod is offline
post #3 of 6 (permalink) Old 07-25-2019, 01:51 PM Thread Starter
Nice install. Do you happen to know what the hub depth of the water pump you used is? Thanks
post #4 of 6 (permalink) Old 07-25-2019, 06:06 PM
Quoted: 20 Post(s)
If I remember right, it's about an inch
Mike R is offline
post #5 of 6 (permalink) Old 07-25-2019, 06:39 PM Thread Starter
I found this on the internet this is the measurement I am looking for: Measure from the top fan hub surface to the water pump mounting surface The industry term for measuring a water pump height is the “hub height”.
post #6 of 6 (permalink) Old 07-26-2019, 08:47 AM
Quoted: 100 Post(s)
The OEM pump you need is C8SE 8505 E,Not too many of them around but a couple of aftermarket pumps on E bay for $250,$300.If you can find a core,Cardone has a rebuild and return deal. The whole thing is not quite as easy as just the pump.Like I said,you need all the pulleys,brackets,balancer,that goes with the short pump.You also need about a 1/4 in shim on the crank spacer.I cut mine off another crank spacer and it works good.
thermod is offline
