460 to 79 Bronco C6 transmission question - 460 Ford Forum
post #1 of 6 (permalink) Old 08-08-2019, 08:29 AM Thread Starter
Hi, i am rebuilding a '73 460 in from a lincoln to swap in my '79 Bronco and i cant find the real answer on whats needed to adapt my Bronco 4x4 C6 transmission to this engine?
I know that i need to use the 460 flexplate but seems like the Bronco torque converter/trans input shaft may not fit directly on the 460.....
Anyone got some infos on this?
Thanks in advance!
Matt
mforget is offline
post #2 of 6 (permalink) Old 08-08-2019, 09:30 AM
Quoted: 100 Post(s)
What motor was originally in the Bronco?
thermod is offline
post #3 of 6 (permalink) Old 08-08-2019, 09:43 AM Thread Starter
Ha yep sorry 351M engine.
Ive just checked and the 351m torque converter seems to fit snug on the '73 460 crank, 460 flex plate holes do align with the 351M converter as well.
Dont know about the Bronco C6 transmission shaft length yet....
mforget is offline
post #4 of 6 (permalink) Old 08-08-2019, 01:06 PM
Quoted: 521 Post(s)
The 351 m / 400 C6 and convertor will bolt up to a 73 460 with out issues. The only difference is 1 less clutch and steel in the forward clutch pack. This is of course contingent on the 460 crank being small pilot which 73 should be.
Large pilot crank has a sharp 90 degree transition from outer register to inner.
Small pilot has a 45* transition from outer to inner.
SJ
used 2b RHP
post #5 of 6 (permalink) Old 08-08-2019, 01:41 PM Thread Starter
SJ
used 2b RHP
Damn you have answers for everything Scott....
Ill go check right now but im pretty sure thats the small pilot...
Thanks again!
mforget is offline
post #6 of 6 (permalink) Old 08-09-2019, 04:02 AM
Quoted: 44 Post(s)
Just recase your trans into the BB case .. Check the converter , it should locate in the crank on the inner step
gregaust is offline
