Looking for some help here as im new to the 460 world. I recently bought a 76' f-150 with the 460 and a c6 tranny. Had it for about 3 days and when i was driving a knock started from under the valve cover. This happened after i put my foot into it to make it downshift up a very, very mild hill RPM was roughly 2800 and a loud bang came from the engine bay. Took the truck back to the house (1km away) and started to do the diagnosis on it. Left it for a couple of days and then finally took the time and tore the valve cover off on the driver side. One pushrod was completely missing the other was bent all to F and was able to fish it out without taking the rocker off. Once i saw this i tore the intake off, found the "missing" pushrod and noticed a bunch of other pushrods were bent. In total 3 pushrods were broke in half, and of the 16 only 6 appear to not have a bend in them; most were a mild bend.
Truck as purchased, (accord to seller)
Has Weiend Stealth intake--Confirmed
Slayer Quick fuel 600 CFM Carb-- Confirmed
Straight up Timing-- Not Confirmed
Crower Power Beast Cam-- Not Confirmed
Original 76' 460
Cam lobes appear to be in perfect condition, all of the lifters looked brand new with no visible wear. The seller supposedly did all the work to this truck 2 years ago and had used it as an occasional driver. So assuming thats correct something must have failed that im not thinking of?
My question(s) are
1. With his cam choice would stock rods have worked? I also think its too much cam for what he has in here but again, im new into this world.
2. With this bad of a failure i dont want to just replace the rods/rockers, something happened and it is NOT an over rev since i have had it, i drove this truck like a grandma. so somthing else must have happened and i need to find that problem first, could the timing have skipped ?
3. Long term goals for this truck was a complete tear down and throw a scat stroker rotating assembly in, Goals were high HP on pump gas. Im saying this because any replacement part on the top end im willing to upgrade if it would help in the future.
And lastly for my job i get free fuel, (regular) so any changes or upgrades for the time being would need to keep me in the 87 octane range.
Anyone else heard of this? Any thoughts?
Original 76' 460
My question(s) are
