460 VS 501 CID - 460 Ford Forum
post #1 of 6 (permalink) Old 09-10-2019, 10:41 PM Thread Starter
jimmyvee2's Avatar
460 VS 501 CID
I'm beginning the build of the replacement engine for my 88 f250 (460efi c6/w205 t case) that burns oil like no other. The engine in question will be about 10:1 compression regardless of displacement chosen, d0ve-a block .030 over, D3 heads (stock valves, warmed over exhaust port), headers, and a lunati cam at 219/227 @050 540/552 lift 110* lobe separation.
I will be using edelbrocks pro flo 4 efi on it and gutting every piece of smog crap and factory efi on the truck.
The crankshaft I will be using needs turned anyway and I don't trust 50 year old rods, so I thought about having it offset ground to 4.14 stroke and just building it to a 501.
So my question is this, is the extra 40 cubes worth it for a simple truck engine? How would it perform compared to a 460 in mpg, torque, ect...?
jimmyvee2 is offline
post #2 of 6 (permalink) Old 09-11-2019, 10:18 PM Thread Starter
jimmyvee2's Avatar
24 hrs and not one person can chime in on this?
post #3 of 6 (permalink) Old 09-11-2019, 10:55 PM
Quoted: 186 Post(s)
lol, seems to happen a lot, go with the 501
BUY,SELL, or TRADE BBF parts
Dynoed or Test STAND RAN
CYLINDER HEAD PORTING
HEAD FLOWING
PRO SYSTEMS CARBS
BOSS 302 351 429 800CI+
BOSS 429 is offline
post #4 of 6 (permalink) Old 09-12-2019, 01:29 AM Thread Starter
jimmyvee2's Avatar
I was kinda hoping someone would say 501. Any guesses as to how fuel economy will be effected? I tend to drive this truck almost every day and with its current 6-8 mpg it gets now (mostly city, and I don't drive anything I own nicely) I can't imagine a fresh engine with a much more modern and efficient efi setup could possibly be any worse, but with the larger displacement I'm not really sure.
post #5 of 6 (permalink) Old 09-12-2019, 05:12 AM
Quoted: 45 Post(s)
Once you've had 500+ cubes you won't go back to a little 460
I doubt with the EFI setup there'd be much difference in fuel economy with the added cubes
gregaust is offline
post #6 of 6 (permalink) Old 09-12-2019, 01:28 PM
1972Mach1's Avatar
Quoted: 36 Post(s)
True that....go with the 501, especially in a truck. More torque is better, your fuel mileage will change very little especially with EFI.
1972Mach1 is offline
