Never run but spun to 12k? - 460 Ford Forum
post #1 of 3 (permalink) Old 09-10-2019, 11:32 PM Thread Starter
The ad says the engine was built but never fired, and was spun 12000 rpm when balenced. Is that a normal proceedure when balencing? It sounds like a decent build. https://vancouver.craigslist.org/rds...951583652.html
File Type: jpg Screenshot_20190910-212952_1568176305525.jpg (8.2 KB, 6 views)
seanb is offline
post #2 of 3 (permalink) Old 09-11-2019, 07:11 AM
Quoted: 38 Post(s)
HI, The balancing machine may be able to turn the crank to 12,000 while cutting it. I don't think the whole motor can be turned to 12,000 rpm's assembled non running? To much for a 1/2 built motor.
61 Comet W/200
pedal2themetal45 is offline
post #3 of 3 (permalink) Old 09-11-2019, 07:16 AM
Quoted: 38 Post(s)
The only thing that is spun and can be spun is the crank, flywheel/flexplate and dampener. the rods, piston, caps and rings are all WEIGHTED and cut to match the lightest one in that set.
good luck
tim
61 Comet W/200
