Starter Solenoid ?s - 460 Ford Forum
post #1 of 6 (permalink) Old 07-26-2006, 09:40 AM Thread Starter
Send a message via AIM to psquare75
Starter Solenoid ?s
So I have many wires on the power stud on my starter solenoid. I've heard that a solenoid with, well, a longer stud, exists. Any idea what car(s) this is from, and where I can get one?
psquare75 is offline
post #2 of 6 (permalink) Old 07-26-2006, 10:52 AM
ByronRACE is offline
post #3 of 6 (permalink) Old 07-26-2006, 11:26 AM Thread Starter
:? I haev some of those already.. I was looking for a cleaner install. Anyone else?
post #4 of 6 (permalink) Old 07-26-2006, 07:37 PM
Maybe you could mount an accessory fuse block next to the solenoid. Some of those wires could probably use a fuse anyway.
Maverick is offline
post #5 of 6 (permalink) Old 07-26-2006, 08:47 PM Thread Starter
NM.. made it work with the solenoid.
The wires were all the OEM wires (fusible linked), plus a new alternator power wire (fused), amp wire (fused), and my extra fuse box (fused, obviously).
post #6 of 6 (permalink) Old 07-26-2006, 09:17 PM
PatFromJersey's Avatar
Send a message via AIM to PatFromJersey Send a message via Yahoo to PatFromJersey
You can add a threaded coupler to the solenoid end, and then run a bolt through the other end of the coupler, with a flat washer on each end of the coupler. This will give you alot of extra room for adding connectors. 8)
New project coming... 1932 Ford 5 Window Coupe 521/C6
PatFromJersey is offline
+ side of starter solenoid getting full..... mach1460 General Tech 3 10-12-2008 11:31 AM
Fender mount starter solenoid to late model truck starter??? BuckeyeBoss General Tech 13 03-17-2008 12:32 PM
Answers to Starter problems using Lakewood Bellhousing ByronRACE Engine Tech 0 06-10-2007 07:49 PM
UGH! Starter Issues. *videos* psquare75 Chilly's Garage 3 07-31-2006 07:21 AM
starter solenoid daxcobra Engine Tech 2 07-25-2006 08:50 AM
