460 in a early 60's falcon? - 460 Ford Forum
post #1 of 8 (permalink) Old 08-20-2006, 09:27 PM Thread Starter
Has anyone here done it? I have a 16 year old boy that wants a 63 falcon futura sprint. He also digs the 460 in my capri & wants to put one in a falcon . Any pit falls or suggestions :roll: I think the engine bay is close to that of an early mustang & will need the shock towers modified/removed for a big block.
bigblock79 is offline
post #2 of 8 (permalink) Old 08-20-2006, 10:08 PM
Haven't done it, but the compartment in those is so smal you'll have to go to a MII/rack type setup at least to make room. And if it's an iron motor, it'll weight nearly 1/3 of the total car weight so it'll not really handlel very well LOL. You'll also need to put subframe connectors in it and -of course- replace the rear end. Replace everything from the trans tunnel down and you'll be good to go.
1967 Falcon 4 door
Owner built, owner abused.
http://raceabilene.com/misc/hisnherspic.jpg
Falcon67 is offline
post #3 of 8 (permalink) Old 08-20-2006, 10:46 PM
1970galaxie's Avatar
W had a guy over her in Perth, Western Australia who had a 460 in his 1965 Falcon Coupe. He completely removed the shock towers, and replaced the front end suspension out of an Aussie Leyland P76, incl disc brakes.
Did the trick.
1970 Galaxie Sportsroof
1972 Falcon XA GT
2003 Falcon BA XR8 ute
1963 1/2 Galaxie Fastback
Check out my website here www.xr8ute.com
1970galaxie is offline
post #4 of 8 (permalink) Old 08-20-2006, 10:55 PM Thread Starter
sounds like my boy will have his work cut out for him , maybe he'll have to settle for a stroker small block :? 347 or a 408 windsor
post #5 of 8 (permalink) Old 08-21-2006, 10:07 AM
Stick with the small block - 331 or 347. Anything bigger (like a 351W block) will be a pain to fit.
1967 Falcon 4 door
Falcon67 is offline
post #6 of 8 (permalink) Old 08-21-2006, 10:14 PM Thread Starter
I think you have a good point, even a windsor is a tight fit with headers
post #7 of 8 (permalink) Old 08-26-2006, 01:08 PM
bib block in a 1963 falcon
see danthefordmans answer to lem&charlie below 5 entries
GTyner is offline
post #8 of 8 (permalink) Old 08-26-2006, 05:25 PM
Had my share of small blocks and had a blast with 'em. But I'm such a big block freak now, that I'd put a tube front clip on that thing (like an A.R.T. or Chassis Engineering) and stick in the big block. Round -fendered Falcons with huge engines have a "Gee Whiz!" factor of about 9.3 and a"fun factor" of about 9.7.
Maverick is offline
460 Horsepower Chart (revised 1/24/09) DJOHAGIN Engine Build Archive 29 07-31-2018 10:46 PM
Early 460 ZF5 flywheel? cadunkle General Tech 3 12-13-2008 01:12 PM
Adjustable rocker conversion on early 460 johns2000 Engine Tech 1 06-13-2008 07:18 AM
460 with Comp 268H cam and SCJA heads? chilly Engine Tech Archive 0 05-09-2006 11:28 AM
460 pistons chilly Engine Tech Archive 0 01-10-2006 10:27 PM
