2001 Stang GT expert needed - 460 Ford Forum
post #1 of 11 (permalink) Old 02-22-2007, 06:15 PM Thread Starter
Send a message via Yahoo to Devildog
Need help here.....Car wouldnt run today.......Throws code P0446.....emission vent or something......changed gas cap...did nothing.....smell raw fuel at times....where is the evap canister located?...and where is the canister purge solenoid located?....cant even find a manual yet...should of already had one......if anyone can help i would appreciate it...if ya need any more info just ask....thanx ahead of time...........D
Devildog is offline
post #2 of 11 (permalink) Old 02-22-2007, 11:15 PM
evap code wont keep it from starting or running,do you have spark and fuel pressure?
you can pull a coil and stick a plug in it and ground the plug to see if you got spark or use a spark tester.
john
bbfstanger is offline
post #3 of 11 (permalink) Old 02-23-2007, 05:32 AM
Not sure which code that is, but the Idle Air Bypass Solenoid on these cars sticks closed after some mileage. They will only run under throttle but will not idle at all. They can be cleaned somewhat...
Don't know if that helps...
When in doubt, throttle out...
www.hardlineoffroad.com
Broncman is offline
post #4 of 11 (permalink) Old 02-23-2007, 06:58 AM
Send a message via AIM to Ranger50 Send a message via Yahoo to Ranger50
Depending on which side of the fuel system the leak is on, it could be a vacuum leak.
The canister should be either on one of the front framerails, was passenger side on foxes, or it is back by the rearend housing/spare tire well.
I would have it smoke tested, you then aren't wasting a pile of cash chasing something that should have or could have been fixed with a $.50 piece of hose.
Never trust an intelligent man with no money to play fair.
1995 Dodge Dakota... Just a LOW daily driver....
1997 F250 PSD -- It's broke, it is a Ford afterall.
Ranger50 is offline
post #5 of 11 (permalink) Old 02-23-2007, 12:23 PM Thread Starter
Thanx guys...i'll look near the spare tire well.......Broncman brings up a good point....it runs when you are using throttle but wont idle...How do I find that solenoid?....Then i had a lapse in reason....I was going to take it in to a guy to check out but I had disconnected the battery when i was messing with it and cleared the codes.....so it was pointless to take it in...have to wait until the light pops on again....thing is it ran good when I reconnected the battery.........D
Devildog is offline
post #6 of 11 (permalink) Old 02-24-2007, 03:29 PM
Idle air solenoid is attached to the front side of the throttle body elbow. If it sticks like that again take a small wrench and whack the cylinder part of the solenoid. That will free up the solenoid and allow the engine to idle. You need to change that thing though. They are cheap enough. Takes about three minutes to do the swap.
SD Wheeler
ShadowLands Racing
2006/2008 Ultra Stang World Champion
Kicker Audio - Exile Turbo - Probe / Coast High Performance - Oakley - Street Car 1320 Clothing
ShadowMaster is offline
post #7 of 11 (permalink) Old 02-25-2007, 11:42 AM Thread Starter
Cool...thanx ShadowMaster.......D
Devildog is offline
post #8 of 11 (permalink) Old 03-02-2007, 12:56 PM Thread Starter
Found what was throwing the code yesterday.....fill tube gasket at the fuel tank is ripped and falling apart.....going to fix it today...gasket at Ford is $90.72....lol
Devildog is offline
post #9 of 11 (permalink) Old 03-02-2007, 12:58 PM
That must be one "fine" gasket :shock:
G. Allen Pearson
cstmwgn is offline
post #10 of 11 (permalink) Old 03-02-2007, 01:31 PM
Sure sounds like someone can't find the right part. With that kind of price, you should get the fuel filler tube too!!!
Ranger50 is offline
post #11 of 11 (permalink) Old 03-02-2007, 04:24 PM
Yeah, I think I'd resort to getting some flat rubber, tracing the filler attaching point, and cutting my own gasket out. You may want to try a few different Ford dealers to see if you can get a better price than that and make sure they're even quoting the right part.
ScottJackson is offline
