5.0 guys..... 1.7 ratio rockers - 460 Ford Forum
post #1 of 10 (permalink) Old 07-15-2007, 06:39 PM Thread Starter
Quoted: 49 Post(s)
i just picked up a set of omega 1.72 roller rockers for a price i could 't refuse in good shape. im going to give them to my brother for his birthday coming up, he has an internally stock 5.0 in his mustang. what other changes do i need for changing from a 1.6 to a 1.72?
new pushrods, or stock length?
new valve springs to handle the extra valve lift created?
will the extra valve lift clear the pistons ok? i believe a stock 89 5.0 has dished pistons in it.
thanks for the input
-Dave
1983 F-250 4x4- 472, NP435, NP205, D60/10.25", 37" bead locks
1983 Mercury Capri- 466, C6, questionably street legal
Dukeofdiamonds is offline
post #2 of 10 (permalink) Old 07-15-2007, 08:35 PM
PBR
Change the springs before they break. You should be fine on piston to valve clearance, I ran a E cam ([email protected] .535/.535) with 1.72 on stock heads and had no problems. Pushrods will most likely be stock length but of course check them to certain.
PBR is offline
post #3 of 10 (permalink) Old 07-15-2007, 08:49 PM
Paul Kane's Avatar
Quoted: 45 Post(s)
Re: 5.0 guys..... 1.7 ratio rockers
Originally Posted by Dukeofdiamonds
i just picked up a set of omega 1.72 roller rockers for a price i couldn't refuse in good shape. im going to give them to my brother for his birthday coming up, he has an internally stock 5.0 in his mustang. what other changes do i need for changing from a 1.6 to a 1.72?
  • Your brother's internally stock 302 will need adjustable roller rocker studs to accomodate the roller rocker conversion.
  • He will also need pushrod guideplates.
  • He will also need hardened pushrods to work with the guideplates. Pushrod length will have to be determined during geometry evaluation.
  • The bone stock 302 has 3/8" rocker studs. Hope that the rockers you purchased are also for 3/8" studs, because 302 roller rockers are available for either 3/8" or 7/16" studs.
  • In a bone stock engine, a valve spring upgrade shouldn't be necessary, although I can't speak for the remaining life expectancy of the existing stock valve springs.
  • Check your piston-to-valve clearance. Very likely okay.
I am selling brand spanking new Miller 7075-T7 roller rockers for 302 Fords, available in 1.6 ratio, 1.7 ratio, 3/8" stud or 7/16" stud. Just $192.
Paul
High Flow Dynamics
Paul Kane is offline
post #4 of 10 (permalink) Old 07-15-2007, 11:13 PM
Omega doesnt make pedestal mount rocker arms? Late model 302's dont use stud mount rocker arms. FWIW, I have no clearance probs ith the stock cam with 1.7's and the bigger valves of the AFR 165's I run. You MIGHT have a problem with the oil baffle in the stock valve covers, nothing that a little tweaking cant fix.
68 coupe, 557+glide...
http://members.cox.net/darkknight302/68nwrear.jpg
84 Gt 'vert, 95 engine, AFR 165's, stock cam, performer with 600 holley
[email protected] in the AZ summer heat
GaryH is offline
post #5 of 10 (permalink) Old 07-16-2007, 12:41 AM Thread Starter
Quoted: 49 Post(s)
thanks for the replies guys, and yes theyre pedestal mount rockers, they just bolt on.
-Dave
post #6 of 10 (permalink) Old 07-16-2007, 12:42 AM Thread Starter
Quoted: 49 Post(s)
oh and gary, ive got some other valve covers we were going to put on it anyways.
-Dave
post #7 of 10 (permalink) Old 07-16-2007, 06:06 AM
That works. The 1.7's cleared my stock 84 valve covers, but I'm not sure if the rail is raised on the AFR's. I used the stock pushrods. Did you get some shims for the rockers?
GaryH is offline
post #8 of 10 (permalink) Old 07-16-2007, 05:47 PM Thread Starter
Quoted: 49 Post(s)
nope, no shims that i know of, where can i find em or can i make them out of something?
-Dave
post #9 of 10 (permalink) Old 07-17-2007, 12:42 AM
http://www.jegs.com/webapp/wcs/store...0002_217272_-1
Pretty cheap really.
Cranes instructions are here for setting up the shims.
http://cranecams.com/pdf/453e.pdf
GaryH is offline
post #10 of 10 (permalink) Old 07-17-2007, 10:55 PM Thread Starter
Quoted: 49 Post(s)
thanks alot gary, im sending him to the local speed shop tomorrow to find some of those shims, i test fit one of them tonight and its pushing the valve open at TDC.
-Dave
