03 Ford powerstroke problem - 460 Ford Forum
post #1 of 7 (permalink) Old 08-02-2007, 11:45 PM Thread Starter
I have a problem with the overdrive button when it is pushed it makes the speedo and tach and gas feed useless and it blows a 10 amp fuse #45 run feed. Never ever had a problem with this truck until tonight coming home from work. Anybody have any ideas.
509stroker4x4 is offline
post #2 of 7 (permalink) Old 08-03-2007, 12:43 AM
Mark Laczo's Avatar
Button
Just had the tow/haul button(shifter) changed out on my 04 as it quit working, wires were all cracked where it went into the steering column. Never caused any other problems just didn't work. By parts numbers there are three different types and of course had to go thru 2 before the third was the correct one. lol Mark L.
Mark Laczo is offline
post #3 of 7 (permalink) Old 08-03-2007, 07:16 AM
richter69's Avatar
been lots of issue over the years on the superdutys with the wires chafing in the column.
69 Grande'
P51 headed 563
3070#'s
5.15 @ 134.89
richter69 is offline
post #4 of 7 (permalink) Old 08-04-2007, 09:03 AM
It's the wires chaffing in the metal gearshift tube. If you can't get a replacement you can disassemble the top cover of the column and unplug the wires, then pull them out of the column shift tube.
This would allow you to at least tape them and just plug it back in without the column assembled. This would be the "get ya home" fix if you need it...
But, it's a very common problem. Be sure to check out www.fordtrucks.com its a great site and has helped me alot with my pickups over the years.
John
jbozzelle is offline
post #5 of 7 (permalink) Old 08-04-2007, 11:17 AM Thread Starter
Thanks for the info I will probably fix it myself with some solder and some shrink tube. Or maybe since its my truck I'll route another button in the little hole right in front of your right knee so its not in the steering column just leave the old button in the shifter.
post #6 of 7 (permalink) Old 08-04-2007, 02:30 PM
It's a little harder than that. I think there is a circuit board in there, not just a button.
John
post #7 of 7 (permalink) Old 08-08-2007, 03:10 AM
WFO
Recall
I see Ford finally had recall on this problem, causing fires on some trucks. Now you can get it fixed for free if you want to go thru the hassle of taking it to the dealership .
WFO is offline
