6.0 Ford Diesel Fuel into the Water Problem - 460 Ford Forum
post #1 of 7 (permalink) Old 10-23-2008, 10:20 AM Thread Starter
Quoted: 185 Post(s)
We have a customer who's getting diesel fuel in the water on a 6.0 Ford Powerstroke diesel any ideas what causes this problem? How do you test the heads to determine the source of the problem....
Dave McLain
McLain's Automotive
DaveMcLain is offline
post #2 of 7 (permalink) Old 10-23-2008, 10:29 AM
richter69's Avatar
Need to pull the heads off and pressure check them, they crack internally.
You can make a fitting to put air into the front of the head in the fuel rail, with the head upside down on the bench fill the water jackets. if you see bubbles its time for a new casting.
69 Grande'
P51 headed 563
3070#'s
5.15 @ 134.89
richter69 is offline
post #3 of 7 (permalink) Old 10-23-2008, 11:27 AM Thread Starter
Quoted: 185 Post(s)
I don't know quite all of the details yet but I do know that they have the heads removed from the engine. Most of the time when they bring heads in for us to check for flatness etc they bring them with no injectors so I should have them put them back in for this test?
Dave McLain
McLain's Automotive
post #4 of 7 (permalink) Old 10-23-2008, 11:37 AM
richter69's Avatar
You'll need injectors, be sure they leave the plug in the fuel galley, then just make a fitting, I think a -4 or -6 an fitting with an oring will fit it if i remember correctly.
69 Grande'
P51 headed 563
3070#'s
5.15 @ 134.89
post #5 of 7 (permalink) Old 10-23-2008, 11:44 AM Thread Starter
Quoted: 185 Post(s)
Ok that's what I'll tell them to do. Thanks.
Dave McLain
McLain's Automotive
post #6 of 7 (permalink) Old 10-23-2008, 11:51 AM
cups
check injector cups in the head not the injectors. head can be cracked also. the cups are most common. i see them all the time.
GT Man is offline
post #7 of 7 (permalink) Old 10-23-2008, 11:56 AM
richter69's Avatar
Injector cups were know for leaking and cracking etc on the 7.3, 6.0 is a different animal. The cups are stainless and very robust, every one I ever had on a 6.0 was a cracked head. On the 7.3 the top of the cup were it seals to the head is interesected in the fuel area on the injector orings, 6.0 the top of cup is below the sealing area. Its possible for the lower oring and the cup to fail, but not likely.
You'll need the injectors to seal of the fuel rail in order to test the integrity of the head, they are needed to plug the hole.
69 Grande'
P51 headed 563
3070#'s
5.15 @ 134.89
