598 dyno numbers - 460 Ford Forum
post #1 of 368 (permalink) Old 11-04-2008, 07:56 AM Thread Starter
598 dyno numbers
we just dynoed a new 598 Motorsport A-head Elim block combo single carb and it went 969 lbs of torque 1287 HP motor made peak Hp at 7200 RPM and didn't fall off until 7600RPM and then only lost 1 HP. More cubes will not gain anymore HP. different heads will be needed to make more HP from this point on. but we feel that were making enough power right now with this set up. we added the NOS set up just for fun....... :roll:
70' Maverick , 557 A-Head 8.90's...1969 #MATCHING MACH1 428 CJ RESTORED 1 of 1....1970 HEMI CHALLANGER
HEMI-HUNTER is offline
post #2 of 368 (permalink) Old 11-04-2008, 08:36 AM
now you just need a car that will handle it...
yours need some severe updating...
Randy
cougar1969 is offline
post #3 of 368 (permalink) Old 11-04-2008, 08:41 AM
CP598's Avatar
Wow, great numbers. Care to share a little more about the combo? I would be interested in head flow number and cam grind.
Thanks.
CP598 is offline
post #4 of 368 (permalink) Old 11-04-2008, 11:35 AM
DAGWOOD41's Avatar
Send a message via Yahoo to DAGWOOD41
:roll: X2 on the combination
Rick
84 Mustang 572 w/glide
DAGWOOD41 is offline
post #5 of 368 (permalink) Old 11-04-2008, 12:29 PM
X3 on the build.
017stosh is offline
post #6 of 368 (permalink) Old 11-04-2008, 01:59 PM
feetfirst's Avatar
Is this with the comp cam?
STOCK SUSPENSION N/A
515 CI in the works!!!
feetfirst is offline
post #7 of 368 (permalink) Old 11-04-2008, 02:12 PM
bruno's Avatar
wow thats alot of hp for that combo :shock: i would love to see a build and flow #s x4
100% free webcam site! | Awesome chicks and it is absolutely free! | Watch free live sex cam - easy as 1-2-3
bruno is offline
post #8 of 368 (permalink) Old 11-04-2008, 03:53 PM
WOW!.... X5 !
'65 T-BOLT is offline
post #9 of 368 (permalink) Old 11-04-2008, 04:29 PM
Fordtek1's Avatar
Re: 598 dyno numbers
so how big of a shot were you spraying to get those #'s?
www.rickscarcare.net
Big Thanks to Chris Corey
aka TopSportsman916
[email protected] ALL MOTOR - NO KOOLAID
Fordtek1 is offline
post #10 of 368 (permalink) Old 11-04-2008, 04:31 PM
IDT-572's Avatar
Quoted: 8 Post(s)
x2
That is a bunch of hp at that low of rpm. And thats by far the best single four, A headed, hp I have ever heard of.
Don't just give us dyno numbers share the build info too............
Blake
580 inch Ported P-51's
1003 hp @7200 810 tq @ 6100
86 Notch
29.5x13.5 Ladder Bar
1.200 60ft 5.41 @ 127.78 mph 8.51 @ 156 mph
200 shot 5.23 135 mph 1.13 60 ft. on the rear tire.
IDT-572 is offline
post #11 of 368 (permalink) Old 11-04-2008, 04:44 PM
gtmustang's Avatar
It must be a set of prototype ProComp A heads! :P 8)
Just kidding- I couldn't resist the opportunity! Thats great HP! :shock: I can hardly hook up what I have, and you have twice the power! Good Job!
Gary
1992 Mustang GT 502 cu/in-631 hp Street Car
A-429 heads, KOOKS headers, Rollerized C-6
gtmustang is offline
post #12 of 368 (permalink) Old 11-04-2008, 05:35 PM Thread Starter
i can't share the build info guys its all top secret... this is my friends motor not mine. he has taken the motorsport A-heads as far as you can go with them without changing the valve angles. the intake was cut in half and CNC'd 4 times before it was done right. we did not spray ANY NOS during the dyno runs.!! My friend does not like to give out info because he is doing all the R&D out of his back pocket and he feels that what he does is his and his info alone. i agree with him. he has spent a tremendous amount of money with this combo and really has it going on now. this motor is going in a 3000lb fox body that will run 7.00'a or around that ET. and yes its a BEAR>>>>>>
i feel blessed that he lets me in on the dyno stuff. sorry thats about all i can say.
post #13 of 368 (permalink) Old 11-04-2008, 05:41 PM
I wont my info
res0rli9 is offline
post #14 of 368 (permalink) Old 11-04-2008, 05:56 PM
feetfirst's Avatar
That would put this motor at the top of all motor heads up classes currently being run that allow 600 CI....... :shock:
post #15 of 368 (permalink) Old 11-04-2008, 06:03 PM
CP598's Avatar
Some quick calculations suggest over 500 CFM on the intake is needed to produce that kind of power. I would assume valve lift would have to be close to 1.00 as well. Didn't think that kind of flow was possible with an "A" head.
Nice work.
CP598 is offline
