My bye run @Cecil County Dragway 10.79 last sunday 11-2-08 - 460 Ford Forum
post #1 of 9 (permalink) Old 11-08-2008, 08:20 PM Thread Starter
nuclearcobra's Avatar
nuclearcobra is offline
post #2 of 9 (permalink) Old 11-09-2008, 12:49 PM
Good run!!!!
What are your car/engine specs?
Mike
545 87LX is offline
post #3 of 9 (permalink) Old 11-09-2008, 05:45 PM Thread Starter
84 hatch 2740 with me in it the motors a 70 460 .060 Dove-a with 68 429 heads c8ve-e that have been ported with 219-173 valves not the right springs tho that cam calls for duel springs,stock crank,paw stage two rods (stockers with good bolts),stealth intake 8012 port matched ,850 dp 80-84 jets 6.5 pv front and rear,cam is comp 292 magnum flat hyd [email protected] lift,crane roller rockers,trw forged pistons flat top with 4 eyebrows cant remember if their dished or not my brother built it 12 years ago the compression test were 190to 193 when i did it a few months back the trans is a c6 from an old box van that i put a tci manuel reverse valve body in it flairs up bad its old. converter is a tci breakaway11" he had in a pickup i can stall it to 1500 thats it anymore it pushes past the beams,headers are hooker 2"-3-1/2" with dynomax 3" bullits,rear is 8.8 with 33# axles and spool,390 gears,slicks are mt 28x9, i shift at 5800 and hit the finish at 6100. It does have a Qa1 k member and coil overs 175lb lakewood shocks 70-30 rear is 50-50 with dodge omni springs and home made ladder bars. the best ever is 10.57 at 128 mph with a 1.490 60'.
post #4 of 9 (permalink) Old 11-09-2008, 07:53 PM
BBFmavrick's Avatar
Nice running car for the parts thats in the engine. 8) :shock: Rick
Rick Brown
Member of a BAND OF BROTHERS
Pro Motion Machining
Bronx Corner Automotive
BBFmavrick is offline
post #5 of 9 (permalink) Old 11-09-2008, 08:29 PM Thread Starter
Thanks cant wait to try a new converter,trans and cam thats my next step and the springs.
post #6 of 9 (permalink) Old 11-09-2008, 09:27 PM
s_stang
Guest
Posts: n/a
Quoted: Post(s)
That's Gett'in it! Awesome run!
Congrats! And TY for the vid!
Les
post #7 of 9 (permalink) Old 11-09-2008, 09:29 PM Thread Starter
post #8 of 9 (permalink) Old 11-10-2008, 09:51 AM
droppedf100's Avatar
Quoted: 6 Post(s)
Damn thats real good with that set up. My motors similar and I went 12.07 on motor but at 4100lbs. Do you know around what the compression is? Pump gas? I dont think my set up would go nearly that fast in a fox body.
I guess you have a bar in the car. I drove my truck 70 miles from my house and got kicked out after my first spray pass running no time It did run 10.85 at 120 though. First and only time there.
droppedf100 is offline
post #9 of 9 (permalink) Old 11-10-2008, 07:37 PM Thread Starter
Its a 10 pt cage and if you went 12.07 at that weight i think you would run the same as me your talkin 1400 lbs lighter your making some good power to run 12.0s at that weight. compression is about 12to1 i think and i run cam 2 110 i tryed 93 and it sputters and spins backwards sometimes when i shut it off. never with race gas. pressure test was 190 to 193 psi.
