2002 Ranger Airbag blink code help - 460 Ford Forum
post #1 of 4 (permalink) Old 11-17-2008, 12:53 PM Thread Starter
skosler's Avatar
#27 is flashing and I noticed the passenger deactivation switch is either not working or the bulb is burned out. What is code 27? I searched the net and couldn't find it for my year model.
I called my local Ford dealer before I realized that the flashing light was actually a code and all they would tell me is that I need to come in and pay $100 for them to run a diagnostic test. I even mentioned that the dash light was flashing randomly, and they did not bother to tell me that its a code if you watch it closely. I asked if my OBD-II scanner would read this and they said "No, you need a $30,000 machine like we have in our shop to read any codes" After thinking about the flashes I googled it and realized that they can be read from the flashes :evil: I feel like calling that dealership back and telling them to stick it. What ever happened to good customer service? I will not go back to that dealer
Sharpen your pitchforks and light your torches... 'CHANGE' is coming!
We say grace, and we say ma'am, if you ain't into that we don't give a damn... cause a country boy can survive!
skosler is offline
post #2 of 4 (permalink) Old 11-17-2008, 01:49 PM
PearsonFan's Avatar
There are 2 codes that could cause the Air Bag lamp to flash a 27. First is a B1884, open or short to ground on the Passenger Air-bag Deactivation (PAD) switch, which can set due to a burned out activation switch bulb. And a B1890, PAD switch short to battery.
PearsonFan is offline
post #3 of 4 (permalink) Old 11-17-2008, 02:25 PM Thread Starter
skosler's Avatar
thanks, that makes sense
skosler is offline
post #4 of 4 (permalink) Old 11-17-2008, 08:29 PM Thread Starter
skosler's Avatar
I went to radio shack and bought a $2 light, soldered it in and the problem is solved.
Ford wanted $100 for a diagnostic test and then $125 for the switch assembly, not to mention their bad customer service. :P
skosler is offline
