460 conversion - 460 Ford Forum
post #1 of 9 (permalink) Old 12-27-2008, 06:28 AM Thread Starter
460 conversion
Happy Holidays to all. Hello to all. I need some advise. I have a 1978 F350 dump truck that had a 400 with standard granny gear 4 speed. I have a 1986 460 engine that I am trying to install in it. I have everything figured out and fitting except the original bellhousing from the 400 doesnt give me enough clearance to bolt transmission to bell. The throw out bearing hits the transmission and there is no clearance to slide it. I could make an adapter probable 1/4'' to bolt between the transmission and bellhousing but dont like that idea. Any ideas?
Rich H is offline
post #2 of 9 (permalink) Old 12-27-2008, 06:44 AM
bruno's Avatar
Welcome to the best forum on the planet ---- man wish i could answer your question but i cant ......
ps -- i would probably move this to general tech ---this section is for non-460 stuff
good luck Bruno 8)
100% free webcam site! | Awesome chicks and it is absolutely free! | Watch free live sex cam - easy as 1-2-3
bruno is offline
post #3 of 9 (permalink) Old 12-27-2008, 08:42 AM
My guess would be that you are using one of the pilot bearings and the shaft splines are running into it. what you need to do is get a pilot bushing for a 390 fe ford and install it, that will sit flush with the end of the crank. The bearings stick out further. I just had this same problem earlier this summer with my pulling truck. Also the flywheel off of the 400 won't work either it needs to be a flywheel off of a 460 or a 390.
Dave
dhlad is offline
post #4 of 9 (permalink) Old 12-27-2008, 09:24 AM
What type of pressure plate is it?Is it the borg type {fingers} or diaphram type?I did this swap on a 79 1 ton and the borg type pressure plate was too thick with the thick flywheel i had for the 460 had to use the diaphram tyoe pressure plate.
brh1969 is offline
post #5 of 9 (permalink) Old 12-27-2008, 02:33 PM
400-460 swap
wonder 400 in a dump ? fe 400? diapham clutch for sure like you said must 351m for bell to fit learn something
Shadetree Garage LLc
new made old
re-volting my specialty get it wired
BFW and BFH oh well
shadetree is offline
post #6 of 9 (permalink) Old 12-27-2008, 03:14 PM
Shadetree....Huh????
brh1969 is offline
post #7 of 9 (permalink) Old 12-27-2008, 05:53 PM
72puller's Avatar
To make the 400 bell work you either need to use a diaphram pressure plate or make a thicker spacer plate. We use thicker spacers all the time on pulling trucks to make room for double disk clutchs. So it's no problem. Just make sure the pilot shaft is in the bushing.
Dennis
72puller is offline
post #8 of 9 (permalink) Old 12-29-2008, 03:24 AM Thread Starter
I am back,sorry for the delay. The original engine was definately a 400. I have removed the pilot bearing and measured all of that and it is fine. I have to use the newer 460 flywheel because it is externally balanced, and the diaphram clutch for the 1986 460. The problem is the transmission is crowded against the clutch arm and throw out bearing. I guess I need to make a spacer plate like puller72 said Thanks for the info.
Rich H is offline
post #9 of 9 (permalink) Old 12-29-2008, 03:27 AM Thread Starter
Sorry that was 72puller.
Rich H is offline
