Never keep track of project $$$$ - 460 Ford Forum
post #1 of 6 (permalink) Old 02-25-2009, 10:52 AM Thread Starter
I did. So far this is what I have with about 15,000 left to go. Still less than an original Boss 429.
Boss 429 Project
1969 S code car $12,500.00
Roll bar caps QF19072PR $89.95
Gas Tank CA93 $132.95
Flip down gas cap C9ZZ9030CR $129.95
Fuel tank mounting HH238 $3.88
Filler pipe hose C8AZ9047 $7.95
Filler pipe gasket C5ZZ9076A $2.30
Filler pipe screws 87N $1.65
Magnum 500 wheels MW1578S $599.88
Lug Nuts 186N $27.95
Boss 429 Center Caps MP1130SET $139.88
Boss 429 Cap decals B69 $31.80
Boss 429 scoop X1021 $124.95
Rear 1/4 extensions 9277023D $239.95
Upper hinge driver 922801 $66.95
Upper hinge passenger 922800 $66.95
Lower hinge driver 922811A $69.95
Lower hinge passenger 922810A $69.95
Ignition & door lock set C9AZ6222050A $24.95
Black Paint 641809 $19.90
POR 15 $100.00
Sway Bar mounting plates 5A775A $24.95
Power Brake Assembly 1509M $119.95
Pedal Shaft Repair PSRK1 $49.95
Ubolts and Nuts 67730 $27.52
Cast Iron Paint NO1 $9.95
Ignition switch removal tool 280488 $9.95
Gauge pod year one $169.95
Dynamat year one $113.85
Gas Pedal Ebay $62.98
1/4 window handle kit Ebay $54.95
1/4 window bolt Ebay $22.95
Glove Box Ebay $37.00
Interior 1/4's Ebay $234.95
Crazy Horse Horn Ebay $91.17
Grant steering wheel 470-1150 $163.99
Horn Button 470-5618 $34.99
7 circuit fuse block 764-70107 $47.99
Gauge wiring 764-30302 $69.99
4 wire terminal 764-40008 jegs $8.99
2 wire terminal 764-40006 jegs $6.99
Electric Speedometer 105-5889 jegs $199.99
Tachometer 105-5898 $126.99
Fuel Level Gauge 105-5715 $39.99
Water Temp gauge 105-5737 $39.99
Voltmeter 105-5791 $34.99
oil pressure gauge 105-5721 $39.99
CD Radio Mounting 18842-2F NPD $99.95
Wiper Bezel 10852-3A NPD $13.50
Ignition Bezel 11584-3 $24.95
Light Bezel 10852-3B $13.50
Light Knob 11661-3 $18.50
Dash Trim Caps 04472-1A $19.95
Splash Shields 16102-69K $124.95
Light Switch 11654-3 $39.95
Headliner HF-90-A $28.95
Headlight switch knob 11661-3 $18.50
Headliner Install tool 935-2 $7.95
Rubber End Cap 04115-1K $0.95
Sun visor bracket 04110-2A $27.90
Black Dash no A/C 04282-1A $354.95
Dash Screws 04282-2K $3.50
Trim Panel 1/4 Pillar 52018-1A $33.50
End Cap Visor 04115-1K $0.95
Visor Screws 04145-7K $1.50
1/4 pillar windlace 31290-1A $31.95
Steering Column 3514-11A $439.95
Pillar Trim 03598-2A $104.95
Windlace WL-A $22.50
Lamp Assembly 13776-2 $67.70
Headlight Dimmer 13A024 $7.95
Brake Light 13480-4 $11.95
Door Light 13713-3 $23.84
VIN Border D-MC205 $15.00
Lock Set Ignition & Doors 22050-2 $21.95
Lock Set Glove Box & Trunk 43507-2 $26.95
Front Speaker 18808-2D $93.50
Ford Wiring Harness 764-20121 Jegs $599.99
MSD Digital 6 plus 121-6520 Jegs $309.99
Inner 1/4 panels & door parts Virginia Must $328.15
Sound proofing & Hood Latch year one $138.90
Hood Hinge Virginia Must $54.00
Hinge springs Virginia Must $11.90
Racing Mirror Virginia Must $124.95
Stone Deflector Virginia Must $19.95
Radiator support Virginia Must $129.95
Heidt Front and rear suspension Tim's Hot Rod Shop $4,061.00
Front Valance Mustang Unlimited $59.95
Rear Valance Mustang Unlimited $54.95
MetalCrafters Fabrication and Body Work $17,000.00
Kaase Heads Jon Kaase $6,000.00
Kaase Intake Jon Kaase $800.00
Engine $250.00
Engine parts and build incl cam, crank, pistons, rods etc $5,000.00
Exhaust Cut Outs Car Shop $530.00
Air Cleaner Car Shop $139.00
Mufflers Car Shop $300.00
Ram Air RanAir.com $600.00
Hydraboost braking system Hydraboost $600.00
Clutch, Pressure Plate etc The Driven Man $1,000.00
Miscellaneous $400.00
Transmission & hydraulic clutch $4,300.00
Header Kit $1,000.00
Total $61,811.41 0
bossofu is offline
post #2 of 6 (permalink) Old 02-25-2009, 10:55 AM
Coupe Devil's Avatar
Dang and I thought I had spent a bunch of money on an unfinished car. I feel for you man.
1990 GT, 347 / 76mm turbo setup OUT AND GONE!
New setup going in. Dove headed 545 with a plate kit to 400, progressive, Th400 etc. etc. etc.
Coupe Devil is offline
post #3 of 6 (permalink) Old 02-25-2009, 11:01 AM
Phantasea466's Avatar
I stopped counting a LONG time ago, I just count year to year for the tax man
Damon Sea
1983 Mustang
534ci
Phantasea466 is offline
post #4 of 6 (permalink) Old 02-25-2009, 11:08 AM Thread Starter
Project cost
On the up side it will be basically a new car. I decided on this one I would go ground up so I would know every bolt that went into the project. I sold the last Mach I had for 55,000 three years ago after owning for 15 years so I'm not that much more into this one.
What would that 55,000 have done in the stock market over the last three years?
bossofu is offline
post #5 of 6 (permalink) Old 02-25-2009, 02:27 PM
Got you about $40k less than you started with !!! LOL
dfree383 is offline
post #6 of 6 (permalink) Old 02-25-2009, 07:23 PM
cletus66's Avatar
Quoted: 29 Post(s)
This is the reason why I usually just sit at the bar in my garage, drink a couple of beers, and look at the cars. Every cool idea I have costs a thousand bucks.
Plus, due to automotive A.D.D. I have probably spent that much money over the last couple of decades, but it is divided among 10 cars, so they are all unfinished money pits. Well, most of 'em.
cletus66 is offline
