460 build on Horsepower TV - 460 Ford Forum
post #1 of 11 (permalink) Old 06-06-2009, 12:06 PM Thread Starter
gtmustang's Avatar
They finally got around to Dynoing the upgraded 460, and it made 607 hp. I think it was probably the E3 "miracle spark plugs" that they used that helped! It sure is nice to see something beside an LS or SB Chevy all the time.
Gary
1992 Mustang GT 502 cu/in-631 hp Street Car
A-429 heads, KOOKS headers, Rollerized C-6
gtmustang is offline
post #2 of 11 (permalink) Old 06-06-2009, 01:08 PM
Hot Rod Lincoln's Avatar
That's the whole reason I dropped my subscription from Hot Rod and Car Craft, all they did was build Chevies. Felt like I was getting the same issue every month.
Hot Rod Lincoln is offline
post #3 of 11 (permalink) Old 06-06-2009, 01:46 PM
Quoted: 11 Post(s)
I can't recall, were they TFS a-460s or Streets?
Also, was it a .030 over 460?
Cam specs?
What was the RPM range?
Thanks!
windsor is offline
post #4 of 11 (permalink) Old 06-06-2009, 02:09 PM
They were streets. I'd be ashamed of an A-head motor making 600 hp.
Maverick is offline
post #5 of 11 (permalink) Old 06-06-2009, 02:16 PM Thread Starter
gtmustang's Avatar
It was a .030 over (466) with T/F Streets & matching intake and the cam was picked by J.Kaase (no cam specs given).
Gary
post #6 of 11 (permalink) Old 06-06-2009, 03:09 PM
it was a hydraulic roller cam. looked like it bolted together pretty easy.
62galxe is offline
post #7 of 11 (permalink) Old 06-06-2009, 03:34 PM
Quoted: 11 Post(s)
That's actually pretty impressive then...at least to me. Seems to go right in line with a number of builds on this forum ...BUT it uses a hydraulic roller. With a big solid roller and P-51's, Kaase "only" made 80 more hp on a very similar short block.
I bet that motor could be built for relatively cheap, as well. I know there is a 521 in the auction section with similar specs.
windsor is offline
post #8 of 11 (permalink) Old 06-06-2009, 04:23 PM
Diggindeeper's Avatar
Gary
i saw that. but guess what the next item after the 460 dyno was...............
AN LS converted to a carb.
Diggindeeper is offline
post #9 of 11 (permalink) Old 06-06-2009, 06:15 PM
HOOK's Avatar
yea ,right after the dyno the first thing joe says is "well that 460 is old school ,now the LS motors are wonder motors" or some crap like that.
but i tell ya 600 h.p on cast pistons........WOW!!!!!!!!
HOOK is offline
post #10 of 11 (permalink) Old 06-06-2009, 07:44 PM
if i remember correctly that ls carb conversion used a 302 distributor.
62galxe is offline
post #11 of 11 (permalink) Old 06-06-2009, 08:33 PM
Sure did. chevy's have to put ford parts in them to be any good.
even then they still are ****.
