2005 F150 - engine removal - 460 Ford Forum
post #1 of 4 (permalink) Old 10-14-2009, 08:14 AM Thread Starter
How difficult is this? Does it require removing any of the front bodywork (or worse?)
I have the opportunity to get a 4wd supercab model for low $ with a serious bottom end knock and copper shavings in the oil. (and failed cam phasers)
Thanks!
Jim
1976 Gran Torino (Starsky and Hutch)
466/C6/4.33 = [email protected] and [email protected]
545/C6/4.00 = [email protected] and [email protected]
See it run at torinocobra.com
Jim W is offline
post #2 of 4 (permalink) Old 10-14-2009, 11:32 AM
Homespun91's Avatar
If memory serves, the factory recommended service procedure is to hoist the cab & front sheetmetal off the frame with a lift after removing the cab bolts & assorted connections. PM richter69...he should be able to confirm/deny...
It may be possible to do it the conventional way, but it sure seems as if there is a lot of crap that is very difficult to get to because of the firewall.
Mike
IN: Staring adversity in the face while working on your car and coming out on top
OUT: Finally realizing that every $%&# thing you touch on your car turns to adversity
Homespun91 is offline
post #3 of 4 (permalink) Old 10-15-2009, 02:35 PM
Lift the cab off. The core support and inner fenders are spot welded on.
557ci 70 Maverick, [email protected] 1.25 60ft.... So far....
A70Maverick is offline
post #4 of 4 (permalink) Old 10-16-2009, 06:27 AM
Fordtek1's Avatar
it can be done by removing the cab or pulling it "old school". removing the cab is usualy the easiest way though......
www.rickscarcare.net
Big Thanks to Chris Corey
aka TopSportsman916
[email protected] ALL MOTOR - NO KOOLAID
Fordtek1 is offline
