88 F-250 RUNS LIKE CRAP - 460 Ford Forum
post #1 of 10 (permalink) Old 10-20-2010, 02:37 PM Thread Starter
I have an 88 f-25 with a 5.8...The other day it started running and idling like crap...If you take off from a light it runs good other than somtimes it acts like a carb with a bad accelerator pump...But its at cruise speed that it screws up,if you hold it say 1500 rpm itll run at that then it will drop a couple hundred rpm then come back up...I put a tp sensor on yesterday which cured the idle problem 100% but still "surges" at speed...fuel pressure is about 35 psi idle and about 40+ on the throttle...checked for vac leaks...Any ideas?
BIGBLOCKB2 is offline
post #2 of 10 (permalink) Old 10-21-2010, 12:31 AM
Hangman's Avatar
IAC acting up??? Does it throw any codes?
Hangman is offline
post #3 of 10 (permalink) Old 10-21-2010, 03:02 PM Thread Starter
No codes and i clean the iac when i had the throttle body off.......HEELLPP
post #4 of 10 (permalink) Old 10-21-2010, 07:21 PM Thread Starter
Ok soo im talking to myself here....I think i may or may not fixed it...The exaust pipe right before the 02 sensor was cracked about 3/4 the way around and was leaking pretty bad.....Maybe sucking air in and givin the 02 a crappy reading?
post #5 of 10 (permalink) Old 10-23-2010, 09:11 AM Thread Starter
Ok did dist cap and rotor,tfi module and tp sensor.still does the same thing...getting a 02 sensor circuit code
post #6 of 10 (permalink) Old 10-23-2010, 02:09 PM
95lightiningguy's Avatar
Send a message via Yahoo to 95lightiningguy
Did you fix the crack in the exhaust pipe. Check the egr valve to see if its workin properly.
89 F150 351w powered
95 F150 300 I6 5 speed soon to be 460 powered lightining clone
95lightiningguy is offline
post #7 of 10 (permalink) Old 10-23-2010, 07:46 PM Thread Starter
FIXED!!!!!It was a wire going to the ecm relay...was broken put still making a connection till i drove it and jarred it around
post #8 of 10 (permalink) Old 10-24-2010, 12:08 AM
Good deal, glad you found it.
post #9 of 10 (permalink) Old 10-24-2010, 07:59 AM
crittersf1's Avatar
Wiring sucks!
crittersf1 is offline
post #10 of 10 (permalink) Old 10-24-2010, 10:15 AM
Hangman's Avatar
^It sure does!! A buddy of mine had a 302 powered '88 F-150 that was a no start. A shop had it for a week trying to figure it out and couldn't. He brought it home and I had it running in two hours. It turned out to be a corroded wire way inside the engine harness. What a pain sometimes.
Hangman is offline
