26" slicks/tires...suspension guru's - 460 Ford Forum
post #1 of 9 (permalink) Old 02-25-2006, 03:31 PM Thread Starter
I have read some are getting by with 26" slicks in the low 10's with no problems. I wonder if I should consider a 26 or stay with a 28.
I have an 85 Mustang with stock wheel tubs, that have to remain stock. I would like to get the rear of the car lower. I think I can get 1" off with some adjustment to the ladder bar setup, but that will be it.
Currently I am running stock 2.3L springs all the way around. Stock style shocks in front, Olds shocks in the back, and ladder bars. At 11.40 the suspension worked great. I estimate it had 480hp, but should be 700 when done. The car should be 2850 at most with me in it.
Do you think the 26's will work on that car? In all likely hood I will have to change suspension components but will run it to see what it needs first. You think I can get it tuned in on 26's without drastic $$$ on suspension?
jpierce55 is offline
post #2 of 9 (permalink) Old 02-25-2006, 06:36 PM
ONEBAD555NOTCH's Avatar
why does the car have to remain stock ?
ONEBAD555NOTCH is offline
post #3 of 9 (permalink) Old 02-26-2006, 05:18 AM Thread Starter
I am shooting for an NMCA class that requires stock wheel tubs.
post #4 of 9 (permalink) Old 02-26-2006, 09:33 AM
nickbay's Avatar
Quoted: 20 Post(s)
700hp on 26" slicks would be tough. Go with the 28", and I think you'll be a lot happier. The trouble is, those cars weren't really made for 28, 26 fit a lot better, but that's a problem with all the mustangs.
nickbay is offline
post #5 of 9 (permalink) Old 02-26-2006, 11:23 AM
Go with the 28"'s. You'll get more contact area with a larger diameter tire. You may have to take a BFH to the wheelwells but that should be allowed.
John
jbozzelle is offline
post #6 of 9 (permalink) Old 02-26-2006, 11:41 AM Thread Starter
I have always done the 28" If I want it lower I will have to roll the lip on the rear quarter, I am not sure how much I can get even then.
I am not sure I can gain anything by smashing the wheel well in on this car. The clearance issue is where the shocks/springs mount and the tub curves out, not the corners.
The entire suspension may need changed to go as low as I wish.
post #7 of 9 (permalink) Old 02-26-2006, 12:13 PM
you can make it work-its very easy to do-and well worth it- there are cars running low 8,s with stock wheel tubs- all you need is a BIG FREAKEN HAMMER
post #8 of 9 (permalink) Old 02-26-2006, 01:49 PM
Send a message via AIM to Ranger50 Send a message via Yahoo to Ranger50
Best advise I or ANYBODY can give....
Buy the BEST shocks AND struts you can get and test, test, test, test, and then test some more.
If guys can go [email protected] on 26x 8.5's, eighth mile, you shouldn't have any problems with running the 26's. Look at the "outlaw" NMRA Real Street times, 9.40's with a 5 speed!!!! they only get a 26x10 to run on......
Never trust an intelligent man with no money to play fair.
1995 Dodge Dakota... Just a LOW daily driver....
1997 F250 PSD -- It's broke, it is a Ford afterall.
Ranger50 is offline
post #9 of 9 (permalink) Old 03-01-2006, 11:11 AM
Phantasea466's Avatar
Ohio Valley Outlaw Street cars are running in the mid to thigh 5's 1/8 mile on 26" X 8.5" slicks :!:
However I'm sure they do a LOT of testing and tuning on the suspension. Just some food for thought :idea:
Damon Sea
1983 Mustang
534ci
Phantasea466 is offline
Percentage of rise.....(pics added) dirt_worker General Tech 37 09-12-2008 10:38 PM
suspension link bruno Chilly's Garage 17 05-05-2008 05:02 PM
Suspension Limiters bulletpruf Chilly's Garage 13 07-23-2007 09:32 AM
driveability of purely street cars above 600hp? chilly Engine Tech Archive 0 05-09-2006 11:11 AM
For guys considering a Must II front suspension conversion chilly Engine Tech Archive 0 01-20-2006 01:55 PM
