Is 650 Flywheel hp realistic with this? - 460 Ford Forum
post #1 of 11 (permalink) Old 03-02-2006, 09:08 PM Thread Starter
D1VE block, studded, O decked, windage tray, 4.50 head gasket .041 , 466 cid ,H beam rods,srp pistons ,flat top -3cc dish. XR292R street roller cam, out of the box 72 cc TFS streets with springs for roller cam, C/R should be about 12.2-1, victor or the new TFS intake,950 carb, 1 7/8 headers. Can it do it ? :?
bigblock79 is offline
post #2 of 11 (permalink) Old 03-03-2006, 08:41 AM
96Mustang460cid's Avatar
I'm not expert, but I don't think you'll be hitting 600 with that combo. Also, if you are anywhere near 600, those headers are WAY too small!
Have a good day!
Michael
2003 F150 Supercrew
BBF
Turbo
1996 Ford Mustang
2.3t w/ HE351VE turbo
12.10 @ 114 mph
96Mustang460cid is offline
post #3 of 11 (permalink) Old 03-03-2006, 10:43 AM
My friend recently had a 472 ci dyno'd that had less compression (11 to 1) and not as good of heads (his were D0VE's with 330/176 flow).
His cam was about the same and he had a dual plane two 4 barrel intake and it put out right at 600 hp.
Based on several other combos I've seen, I would think your combo hits 650 hp pretty easily.
Mike_R_SCJ is offline
post #4 of 11 (permalink) Old 03-03-2006, 12:19 PM Thread Starter
My current combo with a smallish hyd flat tap cam,584 lift & 240 dur @ .050 out of the box RPM heads, dual plane RPM intake, 9.75-1 comp & a puny 750 carb , no windage tray, mech water pump , made 519.8 hp @ 5800 rpm & 540 ft lbs @3600. I would think the 2 1/2 point jump in C/R ,better flowing heads , single plane intake, 950 +cfm carb, & a decent solid roller cam spun to 7000 would get me there? If not what do I need for 650 hp?
post #5 of 11 (permalink) Old 03-03-2006, 02:12 PM
Do the heads flow enough out of the box for 650? I can't remember out of the box #'s. If so yes, but I think you might need a little porting.
Don't buy new heads though, the RPM's can do it with porting for less than the new ones will cost. You may even exceed it.
I suggest you contact a head porter and get a quote.
jpierce55 is offline
post #6 of 11 (permalink) Old 03-03-2006, 04:19 PM Thread Starter
Too late, already have the TFS . They will support the hp #'s I'm looking for.
post #7 of 11 (permalink) Old 03-04-2006, 01:49 PM Thread Starter
I ran my dyno software & it says 627 hp @ 6000 & 614 ft lbs @ 4500 :roll:
post #8 of 11 (permalink) Old 03-04-2006, 01:57 PM
Big Block if I am not wrong flat top with those heads should bring you about 10.7 to 1 or somewhere there about. correct me if I am wrong but to get 12.5 to 1 you need dome pistons? Charlie or someone chime in, the 3cc is just valve reliefs am I not correct?
Randy
cougar1969 is offline
post #9 of 11 (permalink) Old 03-04-2006, 02:17 PM
Fordtek1's Avatar
flat top and zero deck with those heads would be 11.8 to 1 w/ a .041 gasket. the 3cc is just a single intake valve relief if i'm not mistaken.
www.rickscarcare.net
Big Thanks to Chris Corey
aka TopSportsman916
[email protected] ALL MOTOR - NO KOOLAID
Fordtek1 is offline
post #10 of 11 (permalink) Old 03-05-2006, 08:55 PM
bbstickstang's Avatar
Send a message via Yahoo to bbstickstang
i got 12.14 to 1
flat top w/3cc valve relief,4.5 x.041 head gasket,0 deck,72 cc chamber,4.390 bore x3.85 stroke .i figured it to be 12.14 to 1
[email protected] New best, 1.31 60', 12-5-15 All Muscle and No Steroids!
69fb mustang ,509,Liberty Equalizer,5.29 ,31x10.5 w ,3309 w/driver.
I get to feel the torque of a BBF 4 times an 1/8 and 5 times a 1/4.
www.classicgearjammers.org
bbstickstang is offline
post #11 of 11 (permalink) Old 03-05-2006, 11:46 PM Thread Starter
That's what I came up with, thanks... I'm not crazy after all!
Flywheel Help!!!!!!!!! ricer Engine Tech 6 03-01-2008 05:44 PM
Desperately need help regarding flywheel. (update with pics) mechatech Engine Tech 17 03-25-2007 12:45 PM
Flywheel Bolt Washer Question - Here I Go Again :) PatFromJersey Engine Tech 17 10-05-2006 05:40 AM
Flywheel slightly rubs, can anyone help? Phil Engine Tech 5 04-07-2006 08:37 AM
got a flywheel question chilly Engine Tech Archive 0 01-15-2006 10:38 PM
