460 into a foxbody - 460 Ford Forum
post #1 of 13 (permalink) Old 03-13-2006, 10:12 PM Thread Starter
Send a message via AIM to ngates0516 Send a message via Yahoo to ngates0516
460 into a foxbody
any good readings or write ups, on whats involved or needed to do to fit it in there?
ngates0516 is offline
post #2 of 13 (permalink) Old 03-13-2006, 10:42 PM
HEY WASSSSSUP mr ngates0516 the best place too get info is on the big block fox web site they have drop in kit .. i used the kit myself in my 90 stang fits nice good luck have fun peace out!!!!
BIG BLOCK FOX is offline
post #3 of 13 (permalink) Old 03-14-2006, 07:35 AM
96Mustang460cid's Avatar
For my personal experience putting a bbf in a 96 Mustang:
www.cardomain.com/id/96mustang460cid
I believe a few other bbf Mustangs are on the cardomain site also.
Have a good day!
Michael
2003 F150 Supercrew
BBF
Turbo
1996 Ford Mustang
2.3t w/ HE351VE turbo
12.10 @ 114 mph
96Mustang460cid is offline
post #4 of 13 (permalink) Old 03-14-2006, 07:45 AM
dfree383
Guest
Posts: n/a
Quoted: Post(s)
Give Bob At D&D a call.
post #5 of 13 (permalink) Old 03-15-2006, 12:07 AM
BBBob_M's Avatar
Re: 460 into a foxbody
There are quite a few BBFox guys here on 460ford.com who would be glad to answer any questions that you have. We have a few guys in our Yahoo group who have done it also. http://bigblockfox.com
Good luck with your project. You won't be sorry you went big block.
Bob Meyer
www.BIGBLOCKFOX.com
BBBob_M is offline
post #6 of 13 (permalink) Old 03-15-2006, 01:05 PM
Gearhead559's Avatar
< Frpp mounts and hooker super comp. soon to be plated and Drop k member set up...There are a few different ways to do the swap really.
All depends on what you plan on doing with the car...
The heartbeat stops here!
www.gearheadzautomotive.com
Gearhead559 is offline
post #7 of 13 (permalink) Old 03-15-2006, 01:25 PM
Fordtek1's Avatar
I'll second this. Anything you want to know about this swap, Bob can answer in less than 20minutes on the phone! helluva nice guy.
www.rickscarcare.net
Big Thanks to Chris Corey
aka TopSportsman916
[email protected] ALL MOTOR - NO KOOLAID
Fordtek1 is offline
post #8 of 13 (permalink) Old 03-15-2006, 02:41 PM
dfree383
Guest
Posts: n/a
Quoted: Post(s)
I can never get off the phone with him in less than 20 minutes !!! LOL
post #9 of 13 (permalink) Old 03-16-2006, 11:32 AM
Phantasea466's Avatar
:lol: :shock:
Damon Sea
1983 Mustang
534ci
Phantasea466 is offline
post #10 of 13 (permalink) Old 04-17-2006, 07:06 PM Thread Starter
quick question does the firewall have to be moved back...I was told by someone that it did.
post #11 of 13 (permalink) Old 04-17-2006, 08:21 PM
Fordtek1's Avatar
no, it doesn't. My bbf/pg bolted into the stock 5.0 locations w/o any issues and only had to drill 1 hole in the trans crossmember for the GM trans mount
aka TopSportsman916
Fordtek1 is offline
post #12 of 13 (permalink) Old 04-18-2006, 07:57 AM
dfree383
Guest
Posts: n/a
Quoted: Post(s)
I used older 3 pc mounts, Canton Pan, D&D 2 1/8" Headers, JW Glide w/ultra bell, Double hump crossmember, QA-1 tubular K., Manual brake conversion
Modifications Required
1) Notch block and bell on the Passenger side of the motor (Header Clearance)
2) Notch the deep aluminum pan for header clearance (Driver Side)
3) Transmission cross member all the way forward.
4) Spread two header tubes out (hit oil pan) one on each side of the motor.
5) some small triming of misc edges and a little hammer work for header clearance. Nothing major or panel movement required.
6) You will have clearance issues with respect to Water Pump and Radiator / Fan.
7) will need a cowl or equivilent hood for clearance. (I'm using a Ford Racing Dominator Flg Single Plane and A MSD Dist and Neiter will clear a stock hood)
8 Std FL-1A filter worked for me in the stock location.
9) Power booster wil not clear valve covers.
Hope this helps, Also talk with Bob he helped me alot and made things a lot easier and more predictable.
Dave
post #13 of 13 (permalink) Old 04-18-2006, 09:12 AM Thread Starter
Thanks alot guys.
Radiator in a 460 foxbody crculp General Tech 6 09-14-2008 08:26 PM
460 Foxbody Badazgt General Tech 36 08-22-2008 02:41 AM
SOLD Foxbody 460 Swap Oil Pan - $370 Shipped LUS rvesterby The Auction Block 1 04-08-2008 01:57 PM
429/460 ?'s usmcrebel Engine Tech 28 11-27-2007 06:01 PM
Foxbody 460 Badazgt Engine Tech 6 04-08-2007 07:29 AM
