8.8 diff swap - 460 Ford Forum
post #1 of 11 (permalink) Old 03-25-2006, 06:38 PM Thread Starter
8.8 diff swap
Is a 8.8 a direct swap into a 4cyl 87 mustang? Can i use my driveshaft and all other control arms and such? thanks
PS-who makes a mini-spool for the 7.5 ?
Brian
What does it profit a man if he gains the whole world and loses his own soul?
http://therocketshop.blogspot.com/
brian is offline
post #2 of 11 (permalink) Old 03-25-2006, 06:43 PM
Coupe Devil's Avatar
DIrect swap yes.. Im sure someone makes a mini spool for a 7.5... Why I would have no idea..
Coupe Devil is offline
post #3 of 11 (permalink) Old 03-25-2006, 08:51 PM
As was said yes it is a direct swap as long as the 8.8 comes from a Fox body (Tbird, Cougar, Mustang, Fairmont, Towncar, etc, etc.) Why would anyone want a mini-spool in a 7.5? A stock SVO will spit one of those out. If it was me and you just needed one until you could get the 8.8 installed, I'd Lincoln lock it.
Alcatraz95 is offline
post #4 of 11 (permalink) Old 03-25-2006, 09:09 PM
ONEBAD555NOTCH's Avatar
i have one for sale if interested-ill make you a good deal
ONEBAD555NOTCH is offline
post #5 of 11 (permalink) Old 03-25-2006, 09:50 PM Thread Starter
So any of those cars (t-bird, couger, fairmont, towncar) with a V8 will have the 8.8? Do they usually have posi? or just the mustangs have posi ? I have a used set of 3.27 gears so i don't care what ratio I get. Do all the different ratio's go onto the same posi carrier? Or is there different carriers for different ranges of gears?
Brian
brian is offline
post #6 of 11 (permalink) Old 03-25-2006, 09:51 PM Thread Starter
Also what years will work for going into my 87 mustang?
thanks
Brian
brian is offline
post #7 of 11 (permalink) Old 03-25-2006, 10:41 PM
Chuck Stevens's Avatar
From personal experience I can tell you that, at least Thunderbird axles are NOT the same. The T-birds are wider, with longer axle shafts. BTDT.
Chuck Stevens is offline
post #8 of 11 (permalink) Old 03-26-2006, 08:44 AM
The Tbird housing is the same, just the axles are longer. All the 8.8 R&P use the same carrier. I'd go for one out of a 87-88 Turbocoupe. They come with 3.55 w/ a stick and 3.73 w/ an auto, all had TracLoks, and all had disk brakes. You won't be able to use the quad shocks unless you relocate the bracket on the axle (what I did) or relocate the mounting bracket on the car (what my uncle did.) However, w/ good aftermarket control arms, you don't really need the quad shocks. If memory serves, they're only about 1"-1.5" wider from flange to flange than the Mustang. You'll also need an adjustable proportioning valve, but the install is really straight forward.
post #9 of 11 (permalink) Old 03-27-2006, 05:31 AM
Not all the V-8 fox bodies had an 8.8.The most common one is V-8 Mustangs from 86 and up but I have heard that some of the V-8 T-birds/Cougars had them but I think they are fairly rare as all the V-8 T-birds I have seen have had a 7.5..I have also seen them in some of the Lincoln Mark VII's with the 302 HO motor.
ifergusson is offline
post #10 of 11 (permalink) Old 03-27-2006, 11:39 AM
I forgot about the Mark VIIs. If memory serves, only the LSC got the 302 HO and the 8.8. However, they were all 5 lug rear disc (a la SVO.) You'd have to convert the front over as well. If he found a LSC in a salvage yard that still had everything, it would be a very straightforward swap...spindles, rotors, calipers on the front, complete rear in the back. And you are correct, the Mustang got the 8.8 in 86.
post #11 of 11 (permalink) Old 03-27-2006, 11:58 AM
Since you are in Saskatchewan, keep an eye on the total loss vehicles at SGI.I picked up an 88 Turbo Coupe last summer for $400 from them.
Newbie with 429 foxbody swap questions 85foxcoupe429 General Tech 25 04-08-2008 09:02 PM
460 in a 2000 GT swap questions. AmericanIdle General Tech 0 03-08-2008 12:21 PM
What does it take to swap a 460 into a Fox 88Notch General Tech 6 10-07-2007 01:40 PM
WTB 8.8 31 spline open diff 8liter The Auction Block 0 03-09-2007 05:02 PM
1984 Mustang SVO V8 Swap 747JETMECH Chilly's Garage 0 07-07-2006 03:47 PM
