473 Super Cobra Jet Engine - 460 Ford Forum
post #1 of 10 (permalink) Old 06-06-2007, 10:29 AM Thread Starter
I am new to this site and have to say that I am glad to be a part of anything that has to do with Big Block Fords. I mainly race Super Street in NHRA's Division 7 but love to turn the throttle stop off and bracket race also. Here is what I have:
1969 two bolt block with Milodon four bolt caps on the middle three bearings, Cast iron crank of the same vintage ground to .010 on both sides. Scat H-Beam rods connected to dome top Ross pistons producing about 14:1 compression ratio, Super Cobra Jet heads from Jon Kaase with just a small amount of clean up work done to the ports, 2.190 and 1.760 valves with Crower springs and hardware, Harlan Sharp 1.73 ratio roller rockers and a Crower solid roller camshaft. The cam duration at .050 is 260I & 268E, with lift of .720 on both sides, topped with an Edelbrock Victor and a Davinci Spider Dominator. The combo made 810 HP at 6500 RPM and 728 ft lbs of torque at 5000 RPM. It is in a 1986 T-Bird chassis car that weighs 2500# with driver, with a two speed and a Dana 60 with 4.30 gears, best e.t. of 9.03 @ 151 MPH. Thanks for reading
774 SUPER STREET is offline
post #2 of 10 (permalink) Old 06-06-2007, 03:07 PM
Phantasea466's Avatar
Very impressive! What size tire are you running?
Damon Sea
1983 Mustang
534ci
Phantasea466 is offline
post #3 of 10 (permalink) Old 06-06-2007, 03:22 PM Thread Starter
I am running a 32x14.5W Hoosier.
post #4 of 10 (permalink) Old 06-06-2007, 03:29 PM
Great engine :!: :!: Do you have pics :?: :?:
Mike T. aka 511Fox aka"The Pied Piper"
No Sushi Zone
511Fox is offline
post #5 of 10 (permalink) Old 06-06-2007, 03:32 PM Thread Starter
I will try and post some pics tonight
post #6 of 10 (permalink) Old 06-06-2007, 03:55 PM
Reason I was asking, I'm also running a 4.30 gear but 31" X 14" Hoosiers. You must be cranking a LOT of rpm to obtain that kind of MPH. :shock:
Nice combo!
Damon Sea
1983 Mustang
534ci
post #7 of 10 (permalink) Old 06-06-2007, 04:12 PM Thread Starter
Yes, when I turn the stop off it will cross the line at about 7200 RPM which I do not like with the cast crank. I generally run about 6800-6900 on the stop. I am glad to see Scat is offering a stock stroke steel crank now. It will be in my engine when the next freshen up happens.
post #8 of 10 (permalink) Old 06-06-2007, 04:14 PM
That stock crank isn't going to break at that rpm. I wouldn't change it :idea:
Damon Sea
1983 Mustang
534ci
post #9 of 10 (permalink) Old 06-06-2007, 05:07 PM Thread Starter
I hope you are correct on the crank, it just seems heavy and it is cast with high compression and quite a bit of horsepower. It has made it through 350 passes and whatever milage before that.
post #10 of 10 (permalink) Old 12-05-2007, 10:37 PM
DJOHAGIN's Avatar
Quoted: 8 Post(s)
bump
DJOHAGIN is offline
