470 cu. in. EMC engine - 460 Ford Forum
post #1 of 7 (permalink) Old 08-19-2007, 03:16 PM Thread Starter
Quoted: 106 Post(s)
OK ... I've had enough PM's that I figure it might be beneficial to someone if I posted all this engine's particulars.
1 ) D1VE block; 4.470" finished bore size,
(sonic checked to confirm .140" minimum cylinder wall thickness).
2 ) 429 cast nodular crankshaft, offset ground to 3.742" stroke.
Externally balanced rear; internally balanced front.
3 ) 2.2 journals SCAT 6.800" H-Beam rods
4 ) SRP forged pistons, (502 B.B.Chevy flat-top #139511).
intake valve notch machined into piston for FRPP SCJ head
11.7/1 final compression ratio.
5 ) FRPP SCJ cylinder head; simply gasket matched and bowl ported.
2.200" intake valve diameter; 1.770" exhaust valve diameter.
6 ) LAZER solid lifter camshaft;
251/257@.050" - .380"/.376" lobe lift - 107 seperation; 101 intake
7 ) Crane "GOLD" rockers; 1.73/1 ratio.
8 ) Edelbrock 4150 VICTOR intake manifold.
Gasket matched and extensive plenum reworking w/2" adapter.
9 ) Dominator #8896 Holley carburetor.
Rejetted and air bleed changes but, otherwise "out of the box".
10) production front sump CJ oil pan with Canton windage tray.
11) headers were 2" primary, (uneven length), with 3" collectors
12) Magnaflow long body 3" straight through mufflers
peak torque, (629 lb./ft.), occured from 4,800 - 4,900 - 5,000 - 5,100 rpm.
peak horsepower, (703 HP), occured at 6,400 - 6,500 rpm.
torque at 3,000 rpm was 551 lb./ft.
post #2 of 7 (permalink) Old 08-21-2007, 11:43 AM
dfree383
Guest
Posts: n/a
Quoted: Post(s)
Is this for the current challenge?
post #3 of 7 (permalink) Old 08-21-2007, 11:45 AM
Sounds cooool Keep us posted :!: Good luck nuke some "Chebbies" :!: :lol: 8) :shock:
No Sushi Zone
511Fox is offline
post #4 of 7 (permalink) Old 08-21-2007, 11:53 AM
Phantasea466's Avatar
Randy,
Is this the engine that needed the new pistons due to some cooling tower issues while on the dyno? If so, I own $20 worth of those pistons :lol:
I guess that was the $20 worth that was removed for valve clearance :P
Thanks for sharing.
Damon Sea
1983 Mustang
534ci
Phantasea466 is offline
post #5 of 7 (permalink) Old 08-21-2007, 12:30 PM
Send a message via Yahoo to Devildog
Thank you Randy.....D
'71 Mustang Mach1 370 Truck Motor
'09 Shelby GT500
Devildog is offline
post #6 of 7 (permalink) Old 10-07-2007, 02:20 PM Thread Starter
Quoted: 106 Post(s)
This engine was from the 2003 EMC which had a 470 cubic inch limit and performed a whole lot better than I anticipated.
The 509 from 2005 was the engine which needed the new pistons and rings after running with no water till it physically slowed down at high idle as it was siezing-up.
post #7 of 7 (permalink) Old 12-05-2007, 10:31 PM
DJOHAGIN's Avatar
Quoted: 8 Post(s)
bump
DJOHAGIN is offline
