502 tbird - 460 Ford Forum
post #1 of 10 (permalink) Old 03-05-2008, 01:44 AM Thread Starter
502 tbird
I need a little help.My 502 has 11.7 to 1 compression, ported dove-c heads, a .713 lift roller 274/284 by crane,750 holley.This set up with 30 degrees of total timing and a powerglide with a converter that will stall around 5300,went [email protected] shifting at 6000 with the 5.67 gears going through the 660 mark at 6200 rpms.I changed the gears to a 4.56 and slowed car a little, maybe,I did not get enough passes to tell.It ran a [email protected] the first pass and shelled the rearend after I turned the 2step up from 3200 to 3800.The car is a 91 Thunderbird ORSCA 7.00 car that weighs 3300 pounds.I have always run small blocks, and my last 347 would run within 2 tenths of this motor what do some of you big block people think I need to change,we will probaly do more bracket racing this year. I think that the way this motor revs and sounds I am sure there is some more here.I need to decide about a new carrier and gear set?NO MORE SMALL BLOCKS!!!!!
tbird2091 is offline
post #2 of 10 (permalink) Old 03-05-2008, 12:35 PM
dfree383
Guest
Posts: n/a
Quoted: Post(s)
1st thing I see is the Carb is way small, may want a victor and a 1050.... and timing looks a little low for a dove headed motor, Maybe 34-36 would be more in the ball park?
post #3 of 10 (permalink) Old 03-05-2008, 05:38 PM Thread Starter
I have the carb coming,the car has 33-10.5 hoosier tires,what about the gears.I'll try the timing change. thanks ..... Chuck
post #4 of 10 (permalink) Old 03-05-2008, 05:52 PM
Chuck bring your total timeing up to about 36 to 38 and put on a 1050 and a victor and let that thing breath... if you are running 1/8 mile 4.56 if 1/4 mile put 4.10 or 3.90 and use that BBF torque shift that thing up around 6700 and see if it picks up
Randy
cougar1969 is offline
post #5 of 10 (permalink) Old 03-06-2008, 06:50 AM Thread Starter
Well, two people that agree on this,must be geting close.I will test Sunday afternoon and let you know how it goes.thanks
post #6 of 10 (permalink) Old 03-08-2008, 06:05 PM Thread Starter
Here is my tbird. Action shots to follow.
http://i270.photobucket.com/albums/j...Picture020.jpg
post #7 of 10 (permalink) Old 03-14-2008, 03:44 PM
83-88T-Bird Guy's Avatar
Sharp looking Bird you have there. Lokks bada*% with those meats on the back.
Don't see too many of that style Bird.
Alan Mackin
83 T-Bird 460
83 T-Bird Heritage 5.0 RHO
84 T-Bird 5.0
87 T-Bird Turbo Coupe 460
83-88T-Bird Guy is offline
post #8 of 10 (permalink) Old 03-14-2008, 05:26 PM
dfree383
Guest
Posts: n/a
Quoted: Post(s)
I agree with cougar ,You have way to much gear for a BBF.
3.89-4.10 for the 1/4 and 4.56-4.88 for the 1/8
May want to consider talking with your convertor Mfg / Shop too. Could probably use a tune-up / restall, If that convertor was for a small block it may be way too loose.
post #9 of 10 (permalink) Old 03-29-2008, 01:56 AM Thread Starter
I put the 4.88 gear in the bird,run it in on the stands,I heard a noise.I did not think anything about it.When I let the car down I tried the trans brake as I was afraid the trans case might be cracked some where I could not see,the case was fine,the converter is shot.I build a dozen or so powerglides a year for friends and racers.This converter was built just for my index racing,it might need to be different know.How much stall do you like in a heavy car(race only).WHAT NEXT???Chuck
post #10 of 10 (permalink) Old 03-29-2008, 08:02 AM
feetfirst's Avatar
I would order a "custom " stall. It would be around 1200 rpm LESS than your shift point for a glide.
feetfirst is offline
