502 p51 results - 460 Ford Forum
post #1 of 14 (permalink) Old 06-23-2008, 08:13 PM Thread Starter
502 p51 results
79 mustang 502 with stock p51 heads,comp flat tappet cam 272 276 at .50,850 demon vac sec,glide and 8 inh conv,Leaving near off idle with poor traction. Only one full pass so far 1.46 60 foot 6.44 at108 1\8 and 10.10 at 133.5 1\4 .
79must is offline
post #2 of 14 (permalink) Old 06-24-2008, 11:34 AM
bruno's Avatar
what gear and convertor ?? weight of car ?/
nice job by the way -- soon to be in the 9 sec club
100% free webcam site! | Awesome chicks and it is absolutely free! | Watch free live sex cam - easy as 1-2-3
bruno is offline
post #3 of 14 (permalink) Old 06-24-2008, 07:01 PM Thread Starter
Thanks Bruno, Its a 373 with 28 inch tires,coan 5200 stall.The motor has plenty of grunt but the carb might be hurting the top end.
79must is offline
post #4 of 14 (permalink) Old 06-24-2008, 07:07 PM Thread Starter
The car was at 2920 with a windsor But not sure now with the bigger motor.
79must is offline
post #5 of 14 (permalink) Old 07-10-2008, 08:24 PM
dfree383
Guest
Posts: n/a
Quoted: Post(s)
Post some more details, Compression? Head Flows, Header Size? Carb and intake?
Whats done to the suspension?
post #6 of 14 (permalink) Old 07-23-2008, 08:05 PM Thread Starter
It is 12to1,stock p51 heads,victor intake,850 demon carb,2inch hooker headers,The suspension is just your average bolt on control arms in the rear with an air bag. Stock frt struts with aje swap k member. I am sure it will run high nines after tuning,but it started losing oil pressure after a few passes. Im going to pull the pan soon. Hopfully its not to serious
79must is offline
post #7 of 14 (permalink) Old 07-23-2008, 09:33 PM
Send a message via AIM to steves4570 Send a message via MSN to steves4570 Send a message via Yahoo to steves4570
p51 heads
those are some #s,what kind and part # are the pistons.did you go with h-beam rods :?:
steves4570 is offline
post #8 of 14 (permalink) Old 07-23-2008, 10:24 PM
richter69's Avatar
1050 or 1150 make a big difference lol. Its needs more air.
69 Grande'
P51 headed 563
3070#'s
5.15 @ 134.89
richter69 is offline
post #9 of 14 (permalink) Old 07-24-2008, 09:54 PM Thread Starter
Steve they ars scat i beam cap screw rods and srp flat tops with extra valve notches cut for the heads.Not sure on the part number.
79must is offline
post #10 of 14 (permalink) Old 08-13-2008, 10:51 PM
i've been loosing oil pressure after about 1000 foot and i'm running 3/8" clearance between the pickup and the pan. it's a canton setup for a fox if yours is similar i would say increase the distance to 1/2" i plan on doing mine by lowering the bottom of the pan i think. i'll know more after i look at it closer. o yea good work and grads. to ya!
donald pitts is offline
post #11 of 14 (permalink) Old 08-20-2008, 09:21 PM Thread Starter
I finally have oil pressure the entire pass :lol: After adding oil from 7 to 8 quarts with fresh bearings and kendall 20 w50 oil in a miloden pan,I was still losing oil pressure just before the traps 1/4 mile.I changed to amsoil 20w50 race oil at 6 qts and have 80 pounds the entire pass and 70 pounds while braking. So i used my trans brake at 3600 and went 9.97 at 135 but still only a 1.42 60 ft.This is with no rubbing on the intake or heads and a vacuum sec 850 so there is still plenty off potential for upgrades in the future. :!:
79must is offline
post #12 of 14 (permalink) Old 08-21-2008, 10:31 AM
deliveredfast's Avatar
try leaving at 4500 rpm. i use to leave at 3600 with the 2 step and went 10 teens, i took it to 4500 and went 10 o's high 9's. so it dropped my e.t 2 tenths. just something to try, it cant hurt!! jmo.
BBF IDT SHORT BLOCK
18bolt TFS A460 heads
CNC'D by SVRE
TFS Intake ported (SVRE)
COMPCAM by BLAKE
http://i287.photobucket.com/albums/l...ps5280b9cf.jpg
deliveredfast is offline
post #13 of 14 (permalink) Old 08-21-2008, 10:32 AM
oh yeah get you a dominator for sure :lol: :lol: :lol:
BBF IDT SHORT BLOCK
CNC'D by SVRE
COMPCAM by BLAKE
post #14 of 14 (permalink) Old 08-24-2008, 05:31 PM
Great Job, gives my 557 some hope and something to shoot for :shock: Jeff do you have any pictures of the car?? If you don't know how to post them, just email them to me and I will post them
[email protected]
by the way, me and delivered fast both race at Milan! maybe we can all get together one day
D's557BBF is offline
