557 kit - 460 Ford Forum
post #1 of 10 (permalink) Old 07-30-2008, 08:57 PM Thread Starter
Send a message via AIM to steves4570 Send a message via MSN to steves4570 Send a message via Yahoo to steves4570
557 kit
Has anyone used this from Dynoflo Performance Auto Works.557 rotating kit,RPM crank,Probe SRS,Eagle 4340 3D H-beam rods 6.7 or 6.8 with ARP cap screws.Balancing for 100.00.This sells for 1399.00. :?: Thanks steve
steves4570 is offline
post #2 of 10 (permalink) Old 07-31-2008, 01:43 PM
RyanJ's Avatar
Send a message via Yahoo to RyanJ
Those parts are all fine & good, but I think you could get the package for less money someplace else.
For instance: http://www.adperformance.com/index.p...roducts_id=745
And that kit uses a higher-quality crank and you can upgrade to H-beams.
1975 Ford Elite
http://i193.photobucket.com/albums/z...lite_small.jpg
  • Factory 460, work-in-progress...
RyanJ is offline
post #3 of 10 (permalink) Old 07-31-2008, 09:16 PM Thread Starter
557 kit
Thanks RyanJ,i have found that a 577 build can be done for almost for the same amount as a good 466.There are lots of dif kits to chose from and i will look at them close as well talk by phone untill i get the wright one.Good parts cost but make dependable power. :!:
post #4 of 10 (permalink) Old 08-09-2008, 12:10 PM
BBFmavrick's Avatar
You have to have a aftermarket block to go 577. 557 is as big as you can go w/stock block,and it should be sonic tested.Rick
Rick Brown
Member of a BAND OF BROTHERS
Pro Motion Machining
Bronx Corner Automotive
BBFmavrick is offline
post #5 of 10 (permalink) Old 08-13-2008, 09:34 PM Thread Starter
557
BBFMavrick, your wight. I ment to say 557.Going crazy here,trying to build a car and engine at the same time. Have you used a D-D motor plate kit before or know any one that has. At this time it is what i wont to use. :?: :?: Thanks Steve
post #6 of 10 (permalink) Old 08-26-2008, 09:20 PM
BOWTIEKILLER545's Avatar
YOU DONT NEED A AFTERMARKET BLOCK FIND A DOVE-A BLOCK . A 532 IS THE SAME BORE AS A 557 A 4.440 JUST A 4.3 CRANK 6.7 ROD VS. 4.5 CRANK 6.8 ROD :twisted: :twisted: :twisted:
BOWTIEKILLER545 is offline
post #7 of 10 (permalink) Old 08-26-2008, 11:18 PM
https://www.460ford.com/viewtopic.php?t=15925
block info might wanna read it. it seems the d9 block is a good thing.
tubais is offline
post #8 of 10 (permalink) Old 09-15-2008, 01:38 PM
WHat BBF stroker is the best choice for weekend toy?
looking at purchasing a short block from
http://www.racingjunk.com/post/43238...bbf-forge.html
i need to know who can grind me a solid flat tappet for it to make over 650HP
this is going in a 91GT fox body
8 point cage, sub frame connectors, 90/10`s up front 50/50`s out back
10gal cell -8an line to regulator with black pump but the black pump is overheating for some reason so im going to use a aeromotive a1000 pump or a good mechanical if they make one for a BBF?
need advice on what bore and stroke i want 557 is ther eany problem with that?
also this car is a garagae queen comes out a few times a year to do some smoky burnouts and to go to local car cruises/shows and once in a blue moon we may take it to the track any advice on this build is appreciated
dgrobels is offline
post #9 of 10 (permalink) Old 09-15-2008, 08:07 PM
schmitty's Avatar
http://www.carsbycarl.com/
Carl has some real good short blocks, and service after the sale is real good too.
89 F150 mud drag truck
schmitty is offline
post #10 of 10 (permalink) Old 09-17-2008, 08:22 PM Thread Starter
557 now 532
Well i ran across a eagle 532 rotating assembly already balanced, 6.8 h-beam,4.30 steel crank, probe 10663-80. Saveing some cash for some P-51s and mybe i'll slip this thing together over the winter. Have been getting most of my parts from web members and still have a long way to go. thanks steve
