521 Dove Head Project Info (Time Slip added) - 460 Ford Forum
post #1 of 2 (permalink) Old 08-01-2008, 10:59 PM
s_stang
Guest
Posts: n/a
Quoted: Post(s)
Fox Mustang 2645 Lbs
D9 Block .030
Scat Crank 4.3
Scat 6.7 Rods
SRP pistons single valve relief / Flat top Zero Deck
FMS 433 Head Gaskets
Dove Head w/ 2.19 1.78 valves
Home ported with the valve pockets opened for the larger valves
Comp Cam FF-294-B .589 / .615 256 / 267 Installed @ 105
Angus 1.73 Roller rockers
Trend Push Rods 3/8 .080
Victor Dommie Flange Intake
Duraspart Dist 36* total and 11 Int
MSD TN6 (Nascar Box)
Mellings Oil Pump
Canton Pan with girrdle + windage tray
Scat Balancer
Holly Dommie untouched factory setting
D&D 2 1/8 Headders
1" spacer
So far on 9" tires 10.2 @134Mph / [email protected] 107
Will update this post as time goes on.
post #2 of 2 (permalink) Old 08-26-2008, 12:06 AM
s_stang
Guest
Posts: n/a
Quoted: Post(s)
Car is 471.. The 11:05 PM was an aborted run..
Lol Cast Iron heads Rule!
