604 alcohol carby's - 460 Ford Forum
post #1 of 2 (permalink) Old 08-10-2008, 08:50 AM Thread Starter
604 alcohol carby's
hi, i am setting up my younger brother's 604ci- 68/F100 with new twin 1150 quick fuel tech. alcohol carbys, previous setup was old twin 1050 fuel carby's. any help/advice in set/up would be appreciated. these new carb's
have so much adjustability. 604' worked tfs a460 heads, tfs intake. 2 1/4"
primary pipe 4"collector headers, big solid roller cam, msd 7al etc.
IF AT FIRST YOU DONT SUCCEED-----------------SPEND MORE MONEY
blueblood is offline
post #2 of 2 (permalink) Old 08-10-2008, 09:48 AM
richter69's Avatar
The carbs should be close out of the box, give it a a proper fuel supply and let it rip.
Lots of methods for getting the alky set just right, the 10*-15* water temp gain on a pass seems to work for me. As long as its clean and it flys it should be fine, the alky tunning window is much larger.
69 Grande'
P51 headed 563
3070#'s
5.15 @ 134.89
richter69 is offline
