2008 EMC 429 Cobra Jet build - 460 Ford Forum
post #1 of 19 (permalink) Old 03-06-2009, 11:28 AM Thread Starter
Quoted: 106 Post(s)
OK ... recently I have had a barrage of PM's asking about the particulars of the 429 engine I entered in last years EMC.
I answered a couple however, this is getting old, fast. SO, I will post all the information here.
Block = D1VE 4.395" bore
Crank = production car 429 crank, 3.594" stroke
Rods = production "marine" rod with ARP bolts and bushed small end.
Pistons = Diamond "Custom" dished, multiple intake notches for head testing.
Head Gaskets = FRPP
Compression Ratio = 10.44/1
Intake Manifold = TFS "Track Heat", ported to CJ size and Dominator carb flange.
Heads = Kaase P-51 or CNC'd FRPP SCJ's (were both the same score)
Camshaft = CompCams "Custom" FL7133/XX7136 -
280/286@.020" - 251/256@.050" - .371"/.378" lobe lift - 107 seperation;
installed @98 intake centerline.
Rocker Arms = Crane/FRPP - 1.8/1 intake, 1.73/1 exhaust
Timing Set = Cam Research externally adjustable cam drive.
Water Pump = Meziere
Dampner = FRPP
Oil Pan = R.M. Competition "Marine" front sump.
Oil Pump = 1" thick rotor, production truck style M-84D
Carburetor = Excessively modified Holley #8896
Carb Spacer = JOMAR 1" thick, 4 hole, tappered transition
Cylinder Head Flows, Averaged all 8 =
INTAKE
.100" 72.3
.200" 165.1
.300" 253.4
.400" 331.8
.500" 383.2
.600" 404.8
.700" 399.6
EXHAUST (no pipe)
.100" 55.5
.200" 107.5
.300" 144.3
.400" 175.1
.500" 204.4
.600" 228.0
.700" 239.8
I hope that about covers it all.
post #2 of 19 (permalink) Old 03-06-2009, 02:57 PM
No, more? What hp and tork did it make. Thanks
res0rli9 is offline
post #3 of 19 (permalink) Old 03-06-2009, 03:18 PM
Quoted: 11 Post(s)
Read all about it here:
http://www.popularhotrodding.com/eng...fications.html
windsor is offline
post #4 of 19 (permalink) Old 03-06-2009, 04:17 PM
Send a message via Yahoo to Devildog
The torque production is fantastic for an engine that size........D
'71 Mustang Mach1 370 Truck Motor
'09 Shelby GT500
Devildog is offline
post #5 of 19 (permalink) Old 03-08-2009, 01:44 AM
Randy I believe every hp and torq #s I keep saying heads are everthing a simple build like this with good heads will make alote of hp Joe.
torinojoe1971 is offline
post #6 of 19 (permalink) Old 07-26-2009, 11:42 AM Thread Starter
Quoted: 106 Post(s)
Bump for "dutter"
post #7 of 19 (permalink) Old 07-26-2009, 12:41 PM
Randy why run a prod. rod wih that much crazy power?
screamincarbide is offline
post #8 of 19 (permalink) Old 07-26-2009, 12:47 PM
powerstrokeace's Avatar
Was the MPG Adjustable cam gear really worth it and was it really a good piece?
Ace
powerstrokeace is offline
post #9 of 19 (permalink) Old 07-26-2009, 01:29 PM Thread Starter
Quoted: 106 Post(s)
The MPG piece, (actually Cam Research is another division), is a good piece and uses a normal true-roller timing chain. Installation requires a bit of mechanical aptitude.
Piston speed - which is the combination of maximum RPM level and stroke length - along with riciprocating weight will determine what is necessary for strength with a connecting rod.
A stock MARINE rod is plenty strong for that application. The amount of power doesn't matter as a connecting rod is stressed the most in it's EXTENSION not it's compressive mode. AND, these were brand new rods with absolutely NO cycle time.
This combination is less piston speed, (only 65fps), than most production engines and at a lot less reciprocating weight.
post #10 of 19 (permalink) Old 07-26-2009, 04:33 PM
Randy, thanks for the reivew on the piston weight and rod speed.
When I copy your 429cj build, is a truck rod same as the marine?
I have a brand new set of truck rods I would like too use if applicable.
post #11 of 19 (permalink) Old 07-27-2009, 09:27 AM Thread Starter
Quoted: 106 Post(s)
A Marine rod is a truck rod which has been factory magnafluxed to be sure of no flaws.
post #12 of 19 (permalink) Old 07-27-2009, 12:22 PM
orv
Nice numbers! What would cause the dip in torque from 2800-3700? I'm assuming the carb isn't a vac. secondary. Just about forgot to say thanks for all you share!
orv is offline
post #13 of 19 (permalink) Old 07-27-2009, 12:43 PM
billandlori's Avatar
Thats some awesome numbers. Cool to see with the smaller cubes!!
Bill
I salute our troops. Thanks for your service.
"The Key Board Warriors"
1983 Thunderbird
Big Block Power
466 Edelbrock Performer RPM heads, cam, intake
billandlori is offline
post #14 of 19 (permalink) Old 07-27-2009, 12:48 PM
Wave tuning
dfree383 is offline
post #15 of 19 (permalink) Old 07-27-2009, 11:58 PM Thread Starter
Quoted: 106 Post(s)
Dave hit the nail on the head ... a two plane intake manifold gets rid of that dip and also about 60 horsepower.
