460 Bog/Popping - 460 Ford Forum
post #1 of 6 (permalink) Old 06-01-2009, 01:40 AM Thread Starter
460 Bog/Popping
460
D3VE heads, with police spec
2.19/1.76 Ported
performer intake
750 carb
8.5-1 compression
dual exhaust
anyways when i step on it.. she bogs a lil and pops.. Ive played with the timing by moving the distributor.. but she still does it.. any ideas?
Wpginterceptor is offline
post #2 of 6 (permalink) Old 06-01-2009, 09:26 AM
Rodeheaver's Avatar
does it seem like a fuel problem or a spark problem? i know sometimes they are hard to tell the difference... but i see alot of people trying to fix ignition problems when they are having a lean condition... just start checking everything ignition connections, plugs/wires, fuel filters, pumps...
Big block ford JUNKIE,Twin 74mm turboed 501 with procrap heads, [email protected] so far!!! Lots more testing to be had!www.rodeheavershotrod.com
www.unitedgearheads.com
Rodeheaver is offline
post #3 of 6 (permalink) Old 06-01-2009, 05:33 PM
pop
you may have a vacume leak also..spray wd40 around the carb base and anywhere a leak can pop up ..also make sure the vacume advance can on the front of the dizzy is working right..might be frozen from rust or what have ya..
fordmaniack is offline
post #4 of 6 (permalink) Old 06-02-2009, 09:30 AM
Smasher O'Brannan's Avatar
Location: from Ireland, live in lake charles, louisiana
I was going to suggest that as well. I have a harley that develops intake leaks every once in a while and it does the same thing. Pops, crackles, and farts off idle but runs decent when you open it up. cracking the throttle open it just sputters and pops untill I get passed it. Of course now its fixed. Try the spray technique like in the previous post.
73' mustang coupe 514/C6
66' mustang coupe
69 GTO/clone
49' Hudson supersix/390FE Ford
proud member keyboard warriors
and the Southern group
Smasher O'Brannan is offline
post #5 of 6 (permalink) Old 06-03-2009, 06:47 AM
weldonj's Avatar
What type of ignition are you running? My 429 was doing the same thing, and as soon as I put a high voltage coil on it, it hasn't given me a lick of trouble. I thought it may be fuel because the plugs were a dark tan. In first under a load, it would pop and fart, especially around 5500, but no issues now. Hope this helps.
weldonj is offline
post #6 of 6 (permalink) Old 06-03-2009, 08:09 PM
jcoxracing's Avatar
mechanical or electric fuel pump? The reason I ask because my motor did that same thing with an electric pump. The problem was the regulator had my fuel pressure down to 4 psi and when I adjusted it to 7-8 psi the problem disappeared. Justin
jcoxracing is offline
