393 CLEVELAND BUILD HP & TQ QUESS!! - 460 Ford Forum
post #1 of 31 (permalink) Old 03-25-2013, 11:21 PM Thread Starter
bob460's Avatar
Quoted: 218 Post(s)
Just for fun here is a small block build for the cleveland lovers! This engine has been built and dynoed.......heres the specs, all parts are off the shelf
Factory 2 bolt block
4.030 bore, 3.850 stroke
393 cibic inch
Eagle crank
Scat h-beam rods 6 inch
Srp pistons
Heads AFD 2V alloy 200cc OTB....flow 300cfm at .650 lift, exh 219cfm
Intake valves 2.125, Exhaust valves 1.650
Torque Power single plane inatke
Carb is 750 mighty demon, Barry grant
Hvh 1 inch spacer
Cam 264/268 & 666/678 @ 0.050 solid flat tappet, lope sep 110, intake center line 106
Howards roller rockers 1.73
IC&E Distributor
Headers 1 3/4 four into one
Compression 12.1
Timing 30deg
Premium unleaded fuel
Will post the results by the end of the week!
bob460 is offline
post #2 of 31 (permalink) Old 03-26-2013, 02:21 AM
about 620 horsepower??
TorinoStyle2 is offline
post #3 of 31 (permalink) Old 03-26-2013, 09:26 AM
Quoted: 47 Post(s)
660HP @ 7000 RPM
550Tq @ 5500 RPM
DanE is offline
post #4 of 31 (permalink) Old 03-26-2013, 01:14 PM
605 @ 6800 hp
645 @ 6300 trq
jonny z racing is offline
post #5 of 31 (permalink) Old 03-26-2013, 01:17 PM
Quoted: 6 Post(s)
I pulled 500 FT lbs @ 4300 RPM and 500 HP @ 6000 with my last 351C .030 over, ported factory heads, Almost a .600 lift cam 9.8 to 1 comp, ported Torqer.
Things that hurt were Chevy rockers and thier bad geometry reduced lift, intake and 850 BG were too small.
Factory heads ported flowed 330 @ .600 lift, Intake dropped flow to 290, rockers dropped lift to 270 flow numbers.
No real tuning was done while on dyno.
Engine was going in a Pantera so was stuck with the intake. Would have pulled around 650 with correct rockers.
turbo2256b is offline
post #6 of 31 (permalink) Old 03-26-2013, 06:32 PM
Quoted: 24 Post(s)
12:1 comp? must be nice to get access to quality fuel
don't leave us dangling, give us them digits!
'71 torino gt m-code
now- 460 w/roller cam
one day w/t56
anyone wanna donate to my cause?
torinoman is offline
post #7 of 31 (permalink) Old 03-26-2013, 07:14 PM Thread Starter
bob460's Avatar
Quoted: 218 Post(s)
Down here the PUMP GAS is pretty good, so we can run a bit more comp.............digits end of the week...lol
bob460 is offline
post #8 of 31 (permalink) Old 03-26-2013, 07:18 PM Thread Starter
bob460's Avatar
Quoted: 218 Post(s)
Wow 500 FT lbs on a 357ci is dame amazing with 9.8 comp aswell...........what heads did you use?
bob460 is offline
post #9 of 31 (permalink) Old 03-26-2013, 08:00 PM
Quoted: 6 Post(s)
Heads were ported closed chamber 4V. The dyno guys (Pantera freeks) TRIED TO BUY THE ENGINE FROM THE GUY IT WAS BUILT FOR.
You should have seen the first C motor I built with 13.4 to 1. Back in 71/72.
Short block used was a new Aussy NASCAR only 40 or 50 were cast.
It started jumping off the chassis dyno about 8000 RPM. Cranked it to about 9000 shifts. Did have it over 10000 a couple times. It would flip the tack from 3800 to 9000 and more so quick. In a my 69 Shelby Mustang turned 9.36
post #10 of 31 (permalink) Old 03-29-2013, 03:54 AM Thread Starter
bob460's Avatar
Quoted: 218 Post(s)
NICE!!
OK the results (was built 2-3 years ago)
575hp @ 6600rpm
518tq @ 5000rpm
It ran 11.8 @ 121mph in 3650lb xw falcon 1/4 mile on street tyres. Never made another pass, car was sold and then he built a small block 451ci twin turbo making 1500hp on pump gas also going in similar falcon to his last one!
ps- for some reason you guys have a higher reading in the HP rating!!
bob460 is offline
post #11 of 31 (permalink) Old 03-29-2013, 06:55 AM
Quoted: 6 Post(s)
My first thought would be a bigger carb. Dont know anything about the intake used. Another thought is headers I ran were 2 1/8 ID on the Shelby Mustang. With 2 1/2" pipes (nothing bigger back then for mufflers) it lost a lot of power. Also it blew up mufflers ripped the seams out about every 4 months.
post #12 of 31 (permalink) Old 03-29-2013, 08:35 PM Thread Starter
bob460's Avatar
Quoted: 218 Post(s)
I agree, 950 carb with a tfc intake or the new afd intake would work much better, plus bigger 1 7/8 headers would help to push it past the 600hp mark easy IMO. Custom cam would have been a better option aswell.
Just had a buddy who built a 434ci small block with CHI heads on pump gas.............made 780hp & 620tq going over there this weekend to check it out!!
bob460 is offline
post #13 of 31 (permalink) Old 03-30-2013, 12:16 AM
Quoted: 6 Post(s)
The Shelby Mustang motor mentioned was hitting 650 RWHP but shut it down as it couldnt be held down as mentioned and was my DD for years.
Did port a set of Yates heads for a guy about half ported. Was flowing 360 CFM dont remember the lift. Absolutle the quietest heads at that flow of any I have tested or ported. He pulled 720 RWHP it was to be a DD too.
You have to pretend C motors are big blocks and require like 2" or better headers and 3" exhaust.
post #14 of 31 (permalink) Old 03-30-2013, 12:46 AM Thread Starter
bob460's Avatar
Quoted: 218 Post(s)
Have ever played with or built an engine with the aussie CHI heads?
Also have you seen the new CLEVELAND block by ARROW?.....4 bolt mains, thicker webbing, better oilling system so they say.
Its cast in China, but machined in WA, Australia. Looks to be a nice block.........i think around $3200-$3500 aus dollars. Dont know what the max cubic inches are.
Cheers, Bob
bob460 is offline
post #15 of 31 (permalink) Old 03-30-2013, 01:24 AM
If its cast in China, I would'nt waste my money on it.
