1988 F-250 build - 460 Ford Forum
post #1 of 2 (permalink) Old 04-23-2014, 06:01 PM Thread Starter
1988 F-250 build
This is my first post here, (or is it a thread?) so I have no idea how to work this site, or even if I posted in the right spot. Anyway, I just bought a '88 F-250 auto, EFI, 4 wheel drive, single cab long box. I want to build the engine up a bit, I'm not looking to make a 10 second truck, I just want a real brute for pulling. I do a lot of wood cutting with a buddy who has a small block chevy with a cam and headers who thinks hes got all the power in the world and that big blocks aren't good for anything but boat anchors. So basically, I want something to show him up in. I want to run pump gas as this will be my daily driver. This is my first build so I don't want to go to crazy.
All I ask of this build is to:
run on pump gas
be able to pull with the best of them
be reliable
be fairly cheap
and be able to withstand the cold northern Wisconsin winters (-40f or lower at times)
What is a good place to start? how much power will the stock efi system be able to handle? would I be better off throwing a big fat carb on it? What does this engine have going for it and what are the weak points that need to go?
Thanks for any help!
Camper Special is offline
post #2 of 2 (permalink) Old 05-29-2014, 08:52 PM
tuneup
run on pump gas
be reliable
be fairly cheap
Put in a good t-chain set/distributor/plugs/wires, up grade fuel sys and timing
and run best oil and gas..
The 460 doesn't need pistons and rods etc... to run strong .I've rebuilt two w/cam/carb mods
and they both were formidable challenges on the street.........
speedfreak427 is offline
