521 Header Dyno Test - 460 Ford Forum
post #1 of 18 (permalink) Old 05-11-2014, 05:48 PM Thread Starter
460fastback's Avatar
We have just finished bolting together the 521 for my 67 Mustang. The Mustang still has stock schock towers so headers are a bit of an issue. We decided to compare my FPA swap headers to a set of proper 2" tube fox body swap headers we had lying around
Small FPA headers (1-7/8 tubes into 2-1/2" collectors) made only 23 HP less than the fox body swap headers. I was amazed and also very happy. If it was 50 or 75 HP difference I would have had to buy new headers and chop the schock towers.
Engine made 708 HP with the small headers and 731 with the big ones. We didn't go past 6500 RPM as this is a simple bracket racing engine.
1967 Mustang
521 / C6 / 9"
460fastback is offline
post #2 of 18 (permalink) Old 05-11-2014, 09:33 PM
very good info, thanks. what are the engine specs?
wayne
wayney is offline
post #3 of 18 (permalink) Old 05-12-2014, 05:26 AM
bob460's Avatar
Quoted: 219 Post(s)
wayne
x2..........looks like he used p-51 heads nice build.
Cheers, Bob
bob460 is offline
post #4 of 18 (permalink) Old 05-12-2014, 12:35 PM Thread Starter
specs
Scat rotating assembly, Kasse pump, flat top pistons (13 to 1). Comp Cam solid roller from Kasse (0.740 lift , 304 duration, 109 LSA). P-51's, 4150 Victor and Pro Systems 950 DP, MSD dizzy. Everything out of the box, no porting, gasket matching. Just bolt together.
Carb is probably way too small but my goal is mid to low tens (no NHRA license).
Wallace calculator says this combo will do it even with the crappy headers and small carb.
1967 Mustang
521 / C6 / 9"
post #5 of 18 (permalink) Old 05-12-2014, 05:35 PM
Inbred-jed's Avatar
Should easily do it...my 67 fastback ran 10.0s 501 edelbrock head out of the box..11.9:1 ..flat tappet..3.89 gear..c6..I used the cries headers 2 inch primary...worked great for 11 years
Inbred-jed is offline
post #6 of 18 (permalink) Old 05-14-2014, 09:54 PM Thread Starter
Thanks. Looking forward to getting back to the track after a two year break. Although I have aftermarket axles, I'm a bit concerned that I may have to upgrade the 9". It has a Detroit tru track and I'm worried it may not hold up.
1967 Mustang
521 / C6 / 9"
post #7 of 18 (permalink) Old 05-15-2014, 02:33 PM
Quoted: 11 Post(s)
I like it.
windsor is offline
post #8 of 18 (permalink) Old 05-21-2014, 03:09 PM
Gydyup's Avatar
Quoted: 31 Post(s)
Is your Scat forged or cast, and did you go internal or external ballance. YOur build sounds darn close to what I am doing, except compression for me will be around the 10.8 area.
Gydup -67 Coupe, 521 Kaase P51 Comp Solid Roller . Jerico DR4, narrowed & mini tubbed 9 inch with 4:56 spool , Mark Williams Axles on CALTRACS, Shaved towers.
"Owner built-owner abused, if it was easy everyone could have a car like this"
Real cars have three pedals.
Gydyup is offline
post #9 of 18 (permalink) Old 05-21-2014, 05:48 PM Thread Starter
It's a cast crank that is internally
Balanced. I've heard good stuff about Scat. Now I'll see if it's all true.
1967 Mustang
521 / C6 / 9"
post #10 of 18 (permalink) Old 05-24-2014, 08:05 PM
NITROUS FORD's Avatar
Talking
hey 460 fastback nice build! did your cast crank take a lot of slugs to balance it! should run 9.90,s all day long if the car is setup right!
NITROUS FORD is offline
post #11 of 18 (permalink) Old 05-26-2014, 11:37 AM
Quoted: 528 Post(s)
Nice to know. Nice build and great numbers.
At the 600 HP level the headers actually make more torque and lose about 4 HP.
FPA headers have 1 3/4" primary tubes. Mine do and I am not aware of Stan offering them in larger diameters...
Thank you for sharing.
post #12 of 18 (permalink) Old 05-26-2014, 06:45 PM
Fairlanes4ever's Avatar
I have the same rotating assembly with SCJs sitting in my garage waiting to go in my Fairlane. Now I can't wait to get it together!
'63 Fairlane Sport Coupe 434 C6/ Now SCJ headed 521
"Can't nuthin out run my V8 Ford"- Chuck Berry
Fairlanes4ever is offline
post #13 of 18 (permalink) Old 05-26-2014, 07:34 PM Thread Starter
Scott, I'm sure you are correct. 1-3/4" sounds right. I just found it interesting that some of the recommendations called for 2-1/8" stepped headers into 4" collectors. While I'm sure that would make more power, it doesn't mean you can't get there with smaller headers if there isn't a way to fit the bigger ones in.
I guess what I found really interesting is some components (heads, cam etc) had way more effect than others. ( carb, headers )
Just a newbie trying to figure out how to run low tens without chopping schock towers or using NOS.
1967 Mustang
521 / C6 / 9"
post #14 of 18 (permalink) Old 05-26-2014, 10:23 PM
Quoted: 528 Post(s)
Talking
While a larger (than 2") primary likely would have made better peak HP it may have cost you some average. Those HP numbers at a 6400 rpm peak are great. You should see your et goals...
I think this is a really great example of just how good those "tiny" FPA headers really are. Thank you again for sharing your test data. What I like here is the comparison between actual headers for a vehicle vs dyno headers which are typically optimal for HP.
Stan is only a few miles away from me. I think I will start bending his ear about offering them in 1 7/8" primarys.
post #15 of 18 (permalink) Old 06-09-2014, 02:42 PM Thread Starter
Pics of the two different headers ImageUploadedByAG Free1402342927.504366.jpg
1967 Mustang
521 / C6 / 9"
