532 oil psi problem - 460 Ford Forum
post #1 of 8 (permalink) Old 06-20-2014, 12:19 PM Thread Starter
532 oil psi problem
Hi everyone, need some expert help. I have a 532 Ford, lost oil psi at about half track. removed engine from alterd found camshaft broken at cylinders 4 and 8. rear cam brg does not look like it spun in block looks like it was pulled out by the cam? No other engine damage i can see yet. New cam brgs were installed. Bearing shell has no signs of heat scoring?
Shawn
Shawn.D is offline
post #2 of 8 (permalink) Old 06-20-2014, 01:16 PM
Shawn, can you post some pictures so we can see the parts and block???
butterbean is offline
post #3 of 8 (permalink) Old 06-26-2014, 09:24 PM Thread Starter
pic's
Sorry having trouble uploading pictures, engine block is at machine shop, having all oil passages inspected and cleaned. New bearings will be installed along with another cam. I will keep you posted with what we find.
Shawn.D is offline
post #4 of 8 (permalink) Old 07-16-2014, 01:21 PM Thread Starter
Update.
Block back from machine shop, #2 cam bearing had small metal filings behind bearing blocking oil to #2 bearing, block was machined for four bolt mains. Removed all oil plugs, cleaned and boroscoped oil passages, found no more metal filings, installed new cam bearings fitted in new cam turns freely in block. reassembled engine after inspecting all components I will be firing it up tomorrow.
Shawn.D is offline
post #5 of 8 (permalink) Old 08-05-2014, 01:02 PM Thread Starter
Oil pressure
Track day 75psi during warm up, constant 55 psi during all runs. hot idle 35psi touch throttle instant 55 to 60 at 180 deg engine temp. runs and sounds great.
Shawn.D is offline
post #6 of 8 (permalink) Old 08-05-2014, 01:26 PM
Colt's Avatar
Quoted: 98 Post(s)
It's always the small stuff isn't it? Well at least you have a good'n now.
Colt is offline
post #7 of 8 (permalink) Old 10-27-2014, 09:57 PM
BBFmavrick's Avatar
Sounds normal w/race clearances and race oil. Good luck w/it.
Rick Brown
Member of a BAND OF BROTHERS
Pro Motion Machining
Bronx Corner Automotive
BBFmavrick is offline
post #8 of 8 (permalink) Old 10-30-2014, 03:31 AM
Money-pit's Avatar
Quoted: 18 Post(s)
Always set a new or used cam up on V blocks and make sure there is no runout. I've sent Howards back before. Not saying that could have been your problem, just something to always check.
Money-pit is offline
