521" pump gas engine w/SCJ heads - 460 Ford Forum
 1Likes
post #1 of 44 (permalink) Old 11-26-2014, 06:39 PM Thread Starter
Quoted: 74 Post(s)
solid flat tappet cam. The heads are ported.
B F Evans Race Parts
270-278-2376
Lem Evans is offline
post #2 of 44 (permalink) Old 11-26-2014, 06:44 PM
Quoted: 14 Post(s)
Any cam info?
Why is the a/f so rich on the one bank? is that just a sensor reading badly?
either way, awesome numbers
DeepRoots is offline
post #3 of 44 (permalink) Old 11-26-2014, 06:58 PM Thread Starter
Quoted: 74 Post(s)
Originally Posted by DeepRoots View Post
Any cam info?
Because the cheap azz headers did not have bung in them...so the sensor was in the after piping which was blown plum off during the pull.
270-278-2376
post #4 of 44 (permalink) Old 11-26-2014, 08:16 PM
bob460's Avatar
Quoted: 219 Post(s)
Lem nice build............can u share more about the build?
What would be min stall for a street car on this build?
Cheers, Bob
bob460 is offline
post #5 of 44 (permalink) Old 11-27-2014, 09:48 AM Thread Starter
Quoted: 74 Post(s)
Cheers, Bob
The owner intends to use a 3,200-3,400 stall.
O.t.b. tfs 'mafia' manifold, 1050 qfx carb and BP 93 fuel.
270-278-2376
post #6 of 44 (permalink) Old 11-27-2014, 10:24 AM
White Lightning's Avatar
Quoted: 62 Post(s)
Lem, what makes the torque peak RPM so much higher than the HP RPM? Wide lobe center? The longer stroke? Do you have any head flow #s? Thanks.
White Lightning is offline
post #7 of 44 (permalink) Old 11-27-2014, 10:50 AM Thread Starter
Quoted: 74 Post(s)
I'm not sure that i totally understand the question. Relative to the peak hp rpm.....it's governed mostly by the duration of the camshaft. The engine is going in a street driven car and the owner wanted a package that'd live with his converter and an operating range up to ~ 6,000 rpm. So, it was camed accordingly.
The intake side of the heads are 375ish cfm. There was no intent or attempt to make a 400 cfm port. Things were size to fit the application.
270-278-2376
post #8 of 44 (permalink) Old 11-27-2014, 12:45 PM
Nice hp and tq numbers there Lem
kjebba is offline
post #9 of 44 (permalink) Old 11-27-2014, 12:49 PM
Quoted: 62 Post(s)
The torque peak is a lot higher than the HP peak, RPM wise. I've always seen the torque peak below the HP peak, RPM wise.
post #10 of 44 (permalink) Old 11-27-2014, 12:52 PM Thread Starter
Quoted: 74 Post(s)
Peak tq. is @ 4,800 rpm
Peak hp is @ 6,000 rpm
bajarick likes this.
270-278-2376
post #11 of 44 (permalink) Old 11-27-2014, 01:05 PM
Quoted: 62 Post(s)
Oh geez lol. Sorry about that. I'm used to looking at the columns reversed. NEVER MIND! lol.
post #12 of 44 (permalink) Old 11-27-2014, 05:56 PM
bob460's Avatar
Quoted: 219 Post(s)
Too much moooonshine......lol, or maybe not enough!!!
bob460 is offline
post #13 of 44 (permalink) Old 11-27-2014, 09:38 PM
what is the carb pad height on the manifold? nice build i have usually only seen this manifold used on 6700+ rpm motors. do you think a victor would cost much power?
thanks, wayne
wayney is offline
post #14 of 44 (permalink) Old 11-28-2014, 09:10 AM Thread Starter
Quoted: 74 Post(s)
The carb pad is 5/8" taller than the victor.
270-278-2376
post #15 of 44 (permalink) Old 11-28-2014, 04:05 PM
Awesome, This is almost my exact engine. I have a 501 w/ unported scj, TFS mafia, Holley 1050 dom, and flat tappet cam that I am looking to get dyno'd locally over the winter. With a good valve job and bowl blend, do you think I could come close to these numbers with my current cam?
specs are:
•Advertised Duration (Int/Exh): 290/298
•Duration @ .050 (Int/Exh): 257/265
•Gross Valve Lift (Int/Exh): .649/.649
•LSA/ICL: 110/106
•Valve Lash (Int/Exh): .018/.018
•RPM Range: 3000-7200
501coup is offline
