429 Distribuitor Advice - 460 Ford Forum
post #1 of 6 (permalink) Old 01-12-2015, 03:09 PM Thread Starter
Hi everyone, I'm new to this forum and this is my first post, so here goes!
I have a 1955 F100 that's fitted with a stock 429 and a C6 tranny, my question is, I want to swap out the stock distribuitor to an electronic one and was wondering what one you guys could recommend? Like which ones to avoid as I understand there are some cheap copies on eBay, my stock distribuitor's vacuum advance also doesn't work at all so I'd thought id upgrade as I can't be arsed with messing with points anymore either!
Thanks in advance.
woody007 is offline
post #2 of 6 (permalink) Old 01-12-2015, 03:14 PM Thread Starter
woody007 is offline
post #3 of 6 (permalink) Old 01-13-2015, 11:05 AM
Quoted: 15 Post(s)
Get a Duraspark from Scotty at RHP. Parts are easy to get and Scotty can set it up for you. No big deal wiring it and using factory parts, and cheaper to boot!!
jeffgfg is offline
post #4 of 6 (permalink) Old 01-14-2015, 08:48 AM
crittersf1's Avatar
My vote is also for Scotty.
crittersf1 is offline
post #5 of 6 (permalink) Old 01-14-2015, 11:14 AM
White Lightning's Avatar
Quoted: 62 Post(s)
Carl also has the HEI style too.......
White Lightning is offline
post #6 of 6 (permalink) Old 06-09-2015, 05:14 PM
Duraspark
hello all
Little late with this, but with the Duraspark
you can change out the controller for a gm modual
you can even mount it under the Dizzy keep it out of the way,
use the Ford Coil 50K volts
sanddoc is offline
