532 pump gas home made tunnel ram - 460 Ford Forum
 1Likes
  • 1 Post By east coast falcon
post #1 of 9 (permalink) Old 05-03-2015, 08:30 AM Thread Starter
532 10.1 comp. 4.440 probe piston, box stock P51, 6.8 H beam, .080 roller cam bearings ,home built tunnel ram, 2 quick fuel 1050 doms, comp mech roller, .695 .296 @.050 kaase spec. kaase oil pump . All pulls done with sunoco 93. will post dyon sheet when pick up engine. It made 750 at 6100 and 710 tork at 4100 , I'm happy with the results . for my first intake , think I might be a little light on the cam but wanted to put some street miles on it. thanks to all you guys on this site, learned alot , give me your input. Now lets see if my little 64 falcon can stay together.
Devildog likes this.
Ya, thats falcon tail lights.
east coast falcon is offline
post #2 of 9 (permalink) Old 05-03-2015, 02:20 PM
Really nice work and very good results =well done! It would be interesting to know the performance change if you had dyno'd your engine with the single carb.
You could be right about the cam, but great results on the intake work.
racerx2218 is offline
post #3 of 9 (permalink) Old 05-03-2015, 03:49 PM
nice build.
did you do much research on plenum size vs cubic inch and rpm range ?
http://i201.photobucket.com/albums/a...elake3-1-1.jpg
Going fast is only half the fun....what you make go fast is the other.
G-Code is offline
post #4 of 9 (permalink) Old 05-20-2015, 05:27 PM
532 tunnel ram
Any track testing yet? Curious how it compares to your previous set up.
post #5 of 9 (permalink) Old 05-22-2015, 06:14 PM Thread Starter
thanks , Yes did alot of research, on plenum size, just took some time to get the runner size the way i wanted it , without busting through the side of the intake.
post #6 of 9 (permalink) Old 05-22-2015, 06:17 PM Thread Starter
Engine is not in car yet, need to change gears and trans., I don't think my 5 speed will handle that kind of tork.
post #7 of 9 (permalink) Old 05-23-2015, 02:51 AM
Quoted: 45 Post(s)
Nice work , that's tough as !!
gregaust is offline
post #8 of 9 (permalink) Old 05-25-2015, 06:26 AM
nice job. yes you could throw a lot more cam at it but I think you will be fine. Id like to see the dyno sheet.
kyle102565 is offline
post #9 of 9 (permalink) Old 05-27-2016, 05:25 AM
Quoted: 11 Post(s)
Update!?!!!?!?!?!?!?!?!?!?
windsor is offline
