501 build - 460 Ford Forum
post #1 of 5 (permalink) Old 07-02-2015, 06:53 PM Thread Starter
milt460's Avatar
501 build
500 ci 13.1 comp . eagle crank and rods . srp pistons. edelbrock victor heads, port matched. 1050 carb.2"hvh spacer .victor intake, port matched. h6h doug Herbert cam 685lift 260/270 @50 dur 108 lobe center. best et 9.42 @ 142 mph. in 3100 lb 1978 Fairmont. on moroso power speed calculator its making 710 hp
milt460 is offline
post #2 of 5 (permalink) Old 07-02-2015, 07:28 PM
I'm building the almost the same combo 501 ci 13.1 SCJ's that flow 380/260 comp 739/729 and 278/[email protected] ported victor 1050 E-85 and was wondering how much it would make? I'm looking for 750 ish so thanks
butterbean is offline
post #3 of 5 (permalink) Old 07-04-2015, 08:47 AM
TOPHER1's Avatar
504 build
Hey guys my 504 is close to your builds with a small difference. 9.8 to 1 comp with 660 lift 270 dur flat tapped cam Eddy heads (96cc) chamber heads fully ported Mad ported and victor intake alky injected (terminator). in my 2820 mustang was going 5.82-5 @117 MPH and 9.20's at 146+ MPH
with a average 60' 1.27....
Wallace calculators says 710 HP.. Good luck and you should have know problem making 750+
TOPHER1 is offline
post #4 of 5 (permalink) Old 07-07-2015, 08:42 PM Thread Starter
milt460's Avatar
looks like a good combo.if the heads work as good as the flow numbers are.750 hp should be no problem.
milt460 is offline
post #5 of 5 (permalink) Old 08-07-2015, 09:08 PM
any pics???
