466 dyno results low budget build - 460 Ford Forum
post #1 of 11 (permalink) Old 12-22-2015, 02:34 PM Thread Starter
Quoted: 9 Post(s)
466, D3 revised heads, rpm intake, 750 holley, mid length headers, lunati cam 519/542 lift, 214/224. Not radical, very street friendly. In a 92 notch fox.
330hp 400tq
secondaries only opening 1/3. My diaphragm was bad so we pulled a pod from an older holley with surely the stock spring in it, slapped it on as is.
Will dyno again and fine tune it some more. Ran out of time and needed some holley parts. Not sure how much is left on the table.
midnight5.0 is offline
post #2 of 11 (permalink) Old 12-22-2015, 02:54 PM
Quoted: 521 Post(s)
330hp 400tq
Chassis dyno?
post #3 of 11 (permalink) Old 12-22-2015, 03:13 PM Thread Starter
Quoted: 9 Post(s)
Yes. Through a 5 speed.
post #4 of 11 (permalink) Old 12-22-2015, 03:56 PM
Quoted: 521 Post(s)
Was style chassis dyno?
2 roller mustang or single roller inertial?
post #5 of 11 (permalink) Old 12-22-2015, 04:35 PM Thread Starter
Quoted: 9 Post(s)
Single roller, dynojet. Probably an inertia, no brake right? But not 100% sure
post #6 of 11 (permalink) Old 12-22-2015, 05:13 PM
Quoted: 521 Post(s)
Dynojet is an inertial dyno. HP numbers are SAE NET not Gross btw.
Your numbers are not that bad given the lack of WOT and the small cam.
post #7 of 11 (permalink) Old 12-23-2015, 07:55 PM Thread Starter
Quoted: 9 Post(s)
I did have a lean spike at tip in on the dyno read out. Carb has a 31 squirter and orange cam position 1.
Do i increase the squirter size or change the cam?
post #8 of 11 (permalink) Old 01-10-2016, 02:08 PM
Ranchopower's Avatar
Send a message via Yahoo to Ranchopower
Both! 45 squirter and a nice pump cam like a 218
Ranchopower is offline
post #9 of 11 (permalink) Old 01-16-2016, 12:59 AM Thread Starter
Quoted: 9 Post(s)
Update: Dynoed with an 850hp double pumper a while back and the new #s are 350whp and 450wtq.
post #10 of 11 (permalink) Old 08-07-2017, 08:48 AM Thread Starter
Quoted: 9 Post(s)
update*
post #11 of 11 (permalink) Old 08-28-2018, 09:56 PM
What kind of work was done to your heads? gasket match with a little more work on the exhaust side? Or was it much more in depth?
muzz is offline
