AFR 315cc head build 561cid Bracket Engine - Page 2 - 460 Ford Forum
 8Likes
post #16 of 18 (permalink) Old 03-01-2019, 09:51 PM Thread Starter
This is my 1968 F100 Prostreeter I built a few years ago. Its one of my favorites ever!!!
I had a 545cid P51 heads - Hydraulic roller bullet cam - full 3.5 inch exhaust out the back 3.70 gears c-6 trans 4250 lbs - 31x16.50 et streets. It ran 6.90 at 99mph in denton tx. Drive it everywhere and love it. I sold the motor out of it now I have a 10:1 528cid with the trick flow power ports same grind on the hyd roller cam and it runs 11.50`s at 117 in Amarillo TX with air density 6000-7000 feet. I`ll post both engine builds soon and my 589 and 532 that I ran in the mustang uptop.
Tim Trayler is offline
post #17 of 18 (permalink) Old 03-03-2019, 01:39 PM
Tim, Are the Diamond pistons you used custom order units or did you modify a Diamond "off the self" units. Thanks Ed
edwardmats is offline
post #18 of 18 (permalink) Old 03-05-2019, 08:47 PM Thread Starter
Yes They are custom because of the 4.56 bore size on both engines. I usually use ICON pistons - they are really good pistons at a decent price $600.00-$800.00 a set. Just a word of advise - most of your off the shelf pistons- Do Not go off the clearance specs that they put in every box!!! "that little piece of paper with clearance specs" - although if you call the piston manufacture and ask them what they recommend - 90% of the time they will recommend to set them up tighter. BBF Icon pistons street strip 2618 pistons work excellent at .0055. You can set them up at .007 or .008 will work to but you wont get that extra hone job when you refreshing your engine and oil control won`t be as good. I`ve had many that would scream when setup at .0075-.008.
557" AFR 300's Street build 750+ HP @ 6,100 The Mad Porter Engine Tech 45 08-02-2019 08:20 AM
New AFR BBF head 68xr7cat Engine Tech 457 10-29-2018 09:18 PM
Crate engine by SHAFIROFF 547ci AFR head!! bob460 Engine Build Archive 15 09-01-2018 06:32 AM
521 AFR build TPayne Engine Build Archive 0 07-21-2018 10:52 AM
1971 f350 dually AFR 545ci build Fordman1971 Car Buildup Forum 33 06-05-2018 07:14 PM
