F/S: New set of Diamond 4.5" x 4.5" pistons..... - 460 Ford Forum
post #1 of 4 (permalink) Old 07-07-2006, 12:35 AM Thread Starter
fordloverracing's Avatar
I have a new set of Diamond forged pistons that are for a 4.5" bore and a 4.5" stroke. They are domed (12.5cc), CH is 1.235", use a .990" x 2.93" pin and have a .043"-.043"-3/16" ring pak. Takes a 6.8" rod and gives you 572 cu in. Designed for the A-460 heads with 91 cc's gives you about 13.5 CR. Weight is ~632 gm and are 2618 material. Plenty of material to cut domes if wanted. Pins and dual spiro-loks are included. New price was close to $800.00, sell for $700.00. These are new, still in the box. Mistake made when ordered regarding head style.
Located in the Knoxville, TN area, zip 37737. Thanks, Rick
fordloverracing is offline
post #2 of 4 (permalink) Old 07-07-2006, 09:48 AM
faststang902000's Avatar
piston
is this a nos piston u have a part number
faststang902000 is offline
post #3 of 4 (permalink) Old 07-07-2006, 09:50 AM
piston
post #4 of 4 (permalink) Old 07-07-2006, 10:39 AM Thread Starter
The Diamond part number is 40725, job # 24086...............
you can call Eric at Diamond Pistons (877-552-2112) to get more info if you like. Thanks, Rick
New in box Diamond 40422 Kasse SCJ forged pistons for 521 ci 65comet404 The Auction Block 8 12-11-2008 01:31 PM
UPR Products, AJE, and Diamond Pistons snoopstang The Auction Block 2 11-24-2008 08:30 PM
where to order diamond pistons from? ft302351 Engine Tech 9 03-06-2008 04:22 PM
550hp Power Limit? Diamond Street Pistons with 8620 pins playhard557 Engine Tech 24 11-28-2007 08:33 AM
ULTRADYNE rollercam, lifter, spring, retainer + lock set f/s Dave Meister The Auction Block 1 07-20-2006 10:56 PM
