Stroker kits, Shortblocks, and Crate engines - 460 Ford Forum
post #1 of 17 (permalink) Old 09-08-2006, 02:34 PM Thread Starter
CarsByCarl's Avatar
Quoted: 186 Post(s)
Stroker kits, short blocks and crate engines now available.
Distributor for Diamond Pistons, Keith Black, Silvo-Lite, Probe, Hastings, Lunati, Elgin, Melling, Cometic, ROL, King, ACL, RPM, and Pro-Comp.
Stroker Kits
514 Stroker kit-American:
-100% American made parts $1500.00
-Internal balance
-Balanced and ready for assembly.
-Custom options available
-Includes crank, main bearings, rod bearings, I-beam rods, hyper pistons, and rings.
501/514 Stroker kit:
-New Aftermarket parts $1250.00
-Internal balance
521/545 stroker kit:
-New Aftermarket parts $1350.00
-External balance, add $200.00 for internal
Short Blocks
429/460 Short Block
-100% American Made parts $1600.00
-Internal or external balance, your choice
-Forged or Hyper pistons, your choice
-Reman'd stock rods
-Includes: block, crank, main bearings, rod bearings, cam bearings, reman'd stock rods (add $300.00 for H-beam), hyper or forged pistons, and rings. Fully balanced, assembled, blueprinted and ready to go.
514 Short Block-American
-100% American Made parts $2200.00
-Internal balance
-Compatible with regular unleaded when using D3VE (97cc) heads.
-Compatible with premium unleaded when using D0VE (75cc) heads.
-Includes: block, crank, main bearings, rod bearings, cam bearings, I-beam rods, hyper pistons (forged available), and rings. Fully balanced, assembled, blueprinted and ready to go.
501/521/545 Short Block
-New aftermarket internal parts $2200.00
-Internal balance included on 501's
-External balance on 521/545 (add $200.00 for internal)
Crate Engines
Workhorse Crate Engine $4700.00
-514 Cubic Inches (501 and 521 cubic inches also available)
-American Made Parts with 514 rotating assembly.
-Ported iron heads
-Edelbrock Aluminum intake
-Roller Rockers
-Hyper pistons (Forged available)
-Hydrualic flat tappet cam
-453HP at 4700 rpm, 581 lb/ft at 2900 rpm
-Regular unleaded pump gas compatible
-Dyno tested and proven combination.
-Includes: block, complete heads, cam, lifters, rockers, pushrods, intake, water pump, HV oil pump, oil pan, valve covers, crank, main bearings, rod bearings, cam bearings, I-beam rods, hyper pistons (forged available), and rings. Fully balanced, assembled, blueprinted and ready to go.
Street Bruiser Crate Engine $4950.00
-Choice of 501/514/521/545 rotating assemblies
-Ported iron heads
-Roller Rockers
-510 to 525HP at ~5000 rpm, 630 to 680 lb/ft at ~3000 rpm
-Premium unleaded pump gas compatible
Street Brawler Crate Engine $6200.00
-Choice of Edelbrock or TFS Street Aluminum heads
-Roller Rockers
-Hydrualic flat tappet cam (Solid flat available)
-575 to 590HP at ~5500 rpm, 635 to 670 lb/ft at ~4000 rpm
Ultimate Fighter Crate Engine $7150.00
-Choice of 521/545 rotating assemblies
-Forged Crank, internal balance
-4340 H-beam rods or 4340 I-beams, your choice
-Diamond Forged pistons (compression of your choice at no additional cost)
-Diamond file fit plasma moly rings
-Choice of ported SCJ or box stock P-51 Aluminum heads (+$500 for P-51's)
-Edelbrock Aluminum intake of your choice (Victor is standard)
-Scorpion Roller Rockers
-Fabricated aluminum valve covers
-Front or rear sump pan, your choice
-3/8" custom pushrods
-Lunati solid flat tappet camshaft
-Lunati micro polish lifters
-High flow Dynamics oil pump
-600+ HP at ~5750 rpm, 650+ lb/ft at ~3750 rpm
-Full race options
---Lunati solid roller cam & lifters +$500
---750+ HP at 6250 rpm, 675+ lb/ft at 4250 rpm with the solid roller, still on pump gas
---Four bolt main caps +$600
---Moroso pan with screen & baffles +$450
-Includes: block, complete heads, cam, lifters, rockers, pushrods, intake, water pump, HV oil pump, oil pan, valve covers, crank, main bearings, rod bearings, cam bearings, H-beam rods, Forged pistons, and rings. Fully balanced, assembled, blueprinted and ready to go.
Old Pro Crate Engine $3500
-460 Cubic Inches
-Ported iron heads
-350HP at ~4500 rpm, 500 lb/ft at ~3000 rpm
-Regular Unleadedpump gas compatible
-Includes: block, complete heads, cam, lifters, rockers, pushrods, intake, water pump, oil pump, oil pan, valve covers, crank, main bearings, rod bearings, cam bearings, I-beam rods, hyper pistons, and rings. Fully balanced, assembled, blueprinted and ready to go.
Street Fighter Crate Engine $5400.00
-460 Cubic Inches
-Roller Rockers
-Hyper Pistons (Forged available)
-550+HP at 6000 rpm, 575+ lb/ft at 4000 rpm
Custom Options
-Forged Pistons starting at $150.00
-H-Beam rods add $150.00
-Internal balance on 521/545 packages, add $250.00
-Forged steel crank, add $500.00
-Test fire and break-in cam, add $250.00
-Dyno testing, starting at $600.00
-Customer requests, please email for price.
CarsByCarl is offline
post #2 of 17 (permalink) Old 09-11-2006, 12:47 PM Thread Starter
CarsByCarl's Avatar
Quoted: 186 Post(s)
New packages added. Please see above.
post #3 of 17 (permalink) Old 11-06-2006, 06:49 PM Thread Starter
CarsByCarl's Avatar
Quoted: 186 Post(s)
Fresh cores in stock and ready to go. Packages outlined above, as well as custom builds available. Please feel free to call, email, or send a PM with any questions.
post #4 of 17 (permalink) Old 11-09-2006, 05:32 PM Thread Starter
CarsByCarl's Avatar
Quoted: 186 Post(s)
New 501, 521, and 545 packages added. Custom builds always available.
post #5 of 17 (permalink) Old 01-23-2007, 10:24 AM Thread Starter
CarsByCarl's Avatar
Quoted: 186 Post(s)
Bump
post #6 of 17 (permalink) Old 01-24-2007, 03:18 AM
do you sale prepped blocks,4.44 bored? if so how much?
BBsteve is offline
post #7 of 17 (permalink) Old 01-24-2007, 10:22 PM Thread Starter
CarsByCarl's Avatar
Quoted: 186 Post(s)
Sure. Send me an email or PM with specifics about what you're looking for. Decking? Oil mods? 4-Bolt? Block fill? etc.
post #8 of 17 (permalink) Old 01-27-2007, 02:17 AM
Code Blue Racing's Avatar
Check this out;
https://www.460ford.com/viewtopic.php?t=8836
Jim Rich
Code Blue Racing CJ 72 - COR 72
JR Performance Motorsports
Jet Drive Service & Repair
Office 928-219-4929
Sprint 928-542-7712
www.e-PerformanceMarine.com
Proud Father of the J 53 C Driver "Lil Miss Dynamite" Amanda Rich
2010 Comp Jet Sponsors;
Foxwell Motorsports, High Flow Dynamics, CP Performance, Finney's Plastic & Powdercoating, IntakeElbows.com, Vintage Rod Components, ABBOTTCRAFT, TourHavasuHomes, Arizona Aircraft Interiors.
Code Blue Racing is offline
post #9 of 17 (permalink) Old 01-29-2007, 08:26 AM
crate motor
could you quote a 460 with alum. heads with a solid lift cam forged pistons with h beam rods. this is a drag only motor usedwith dominator intake with a powerglide with a brake shipped to dock to zip 37405. thanks
mustanggt3 is offline
post #10 of 17 (permalink) Old 01-29-2007, 09:48 AM Thread Starter
CarsByCarl's Avatar
Quoted: 186 Post(s)
Re: crate motor
That would be similar to the Street Fighter package, but I can tailor compression, cam profile, and power output to meet your needs more closely. With the additions of the H-beams, forged pistons, solid lifter cam, dominator intake, and shipping to the nearest major airport, it would run about $5850.00.
Feel free to email me direct or give me a call if you have any other questions.
Thanks,
Carl
post #11 of 17 (permalink) Old 02-08-2007, 06:39 PM
bda55's Avatar
Hi, looking at options for a crate engine, would you freight to Australia?
I want to build a blown(8/71, carbed), 514 ci +, pump fuel (98 octane), street engine with 700 + hp.
I have been looking at the Ford Racing 514 crate engines with 8.9:1 comp and then buying a The Blower Shop 8/71 kit and a pair of BG blower carbs. I have worked out it will cost me about $23500 Australian, including freight and tax(GST).
1975 XB Falcon Coupe, 351/toploader/4.11:1 9"
1974 XB Falcon Ute, as above driveline,(soon to be blown big block stroker)
bda55 is offline
post #12 of 17 (permalink) Old 02-08-2007, 06:42 PM
bda55's Avatar
Going into this.
http://forum.streetfords.com.au/atta...3&d=1161764948
http://forum.streetfords.com.au/atta...7&d=1161765445
bda55 is offline
post #13 of 17 (permalink) Old 04-06-2007, 10:52 AM Thread Starter
CarsByCarl's Avatar
Quoted: 186 Post(s)
Bump.... :arrow:
post #14 of 17 (permalink) Old 05-27-2007, 01:26 PM
jrocco's Avatar
Hi Carl
On your stroker kits, are the cranks set up for the 2y 1.850 or the 2yabc 1.375 converter pilot?
-Internal balance
-Internal balance
Jerry Tomasello
70 Torino 429
Club Moderator - the Ford Torino Club
http://autos.groups.yahoo.com/group/TheFordTorinoClub/
jrocco is offline
post #15 of 17 (permalink) Old 05-27-2007, 08:11 PM
sroker
Carl do you do the oil modifications to your motors?
torinojoe1971 is offline
