460 block,crank,rods,pistons,cam,lifters, aluuminum heads - 460 Ford Forum
post #1 of 4 (permalink) Old 01-10-2007, 12:22 PM Thread Starter
D1VE block, 2 bolt main, ARP bolts, bored.030 over, 2YAB crank turned .010 under, chamfered oil holes, D00E rods with ARP bolts, with TRW 30 over forged pistons with the .400 dome, Ford Racing 1.7 aluminum roller rockers,Manley chrome moly swedged end push rods( 7 hrs of use) brand new in the box Comp solid flat cam and lifters grind # 306S, 306 dur.640 lift. New in the box CAT forged H beam rods( stock length) Edelbrock Performer RPM heads 95cc ( 7 hrs of use and un ported) Motor is apart, I pulled it 4 months ago to freshen it up and decided to find a bigger one. Everything is mint, clean no cylinder wall scratches. around 60 passes on the shortblock and oil changed every week. $ 2500.00 Canadian or trade for??
46686stang is offline
post #2 of 4 (permalink) Old 01-10-2007, 03:54 PM
Heads
I would be intreasted in buying the heads separate if your willing .. also what cc are they
Bluustang71 is offline
post #3 of 4 (permalink) Old 01-10-2007, 04:34 PM
I have a 4.150 crank,8 alum. rods,a set of 4.440 Venolia pistons. if your interested i might be interested in the heads, and cam.
1971mavrick is offline
post #4 of 4 (permalink) Old 01-10-2007, 05:16 PM Thread Starter
I would like to keep it all together but if nothing I will let you know
